I think on short river trips, I'll keep the big motor then offset the kicker weight by port side mounted batteries in the cabin when I take the kicker.
So here's to nightmare on restoration street...
Gel coating the deck has been coming out pretty good. Really good adhesion. Yes, there's a hump on the seam. Lesson learned for next time. most of the deck will be covered in Interlux Gray, in taped off patterns, so hopefully it won't be too too noticeable.
Drilled the jackplate/motor mounting bolt holes then drilled them out to "core" them.
Mixed up a PB with Cabosil and lots of cut up cloth for strength...
Went to drill them out, starting from both ends...forget it. It drilled fine, but the glass is too hard and there were some hairline cracks. Definitely don't want my motor bolts vibrating inside brittle glass cores.I don't suggest this method.
I redrilled them and filled the holes with US Composites thick epoxy and SM fairing compound. I put the halogen lights near the inside of the transom and the epoxy kicked off. I placed the halogens at the back of the transom for 1/2 hr and a HUGE blister developed. At first, I thought that the Awlgrip let go. I stabbed the bubble with a wood chisel and it was under extreme pressure. It appears that the heat damaged the layers of the transom skin very, very deeply.
She's dirty and was never painted under the jackplate. I'm going to have to repair this and repaint the entire rear of the boat. It's going to set me back quite a bit.
All in all a slow go.
