jc55
- Nov 3, 2006
- 665
Finally got the top transom holes. I used thickened epoxy, drilled a small pilot hole and went up in size, 'creeping' up on the final size so as not to rip, tear, crack the epoxy and added some CSM over over that. Next up will be chamfering the holes through the CSM, sanding the last final 1/5th of the deck and transom and gel coating that.
Inside.
Outside.
My heated commercial shop is being leased so I'm really trying to do what I can with propane heaters, heat lamps, plastic tarps, insufficient air compressor, etc. I may have to rent an air compressor to repair, prep, primer, and Awlgrip the outside of the transom skin since I really screwed it up having the heat lamp too close.
Inside.
Outside.
