Looking good jc this is the guy I used for my tank I found him to be reasonable WWW.SPEEDYTANKS.COM
Thank you both! I got her in today (whew) with the help of my dad and kids. I coated the back of the transom with resin and let that set, Installed a layer of 1708 (the only thing I use) CSM side against the transom skin (stronger styrene bond as per your article Wood). Then PB on the hull, and transom skin side, slipped her in without cutting the gunwales or stringers and clamped her up.
This transom was so rigid and so large, that I was pressing the outer skin against the transom, not the transom to the skin like my last boat, if that makes sense. Bolted through the drain hole and used my custom jacking clamps on the inside.
Jig, your cooler trick worked like a charm! Thanks, got the rest on ice for tomorrow's PB filleting.
It ain't pretty but she'll be solid now. 11 days so far.
The new tank should be in this week so that I can continue on the deck.
Is there any magic in installing a garboard drain and 1 1/4" scupper brass drains? I have the smaller 1" compression tool.
Also, someone went from a small round access hatch over the bilge to a larger rectangular hatch. Is this killing my transom support? That is, having a hatch in front of my deck to transom joint?
The deck edges were almost 1" away from the hull and caulked with something. I don't want to cabosil/PB the deck edges before tabbing because of the thin hull side. The hull is beautiful and I don't want to see the deck line from the outside due to heat distortion or heavy pounding. Any suggestions? Maybe a strip of thin foam, then some PB?
Okay but if my hull develops an extra set of "double chin(e)s" [That was darn funny] I'm gonna come looking for ya :lol:
