1989 wellcraft 230 coastal I/O fiberglassing
ltfella
Ok so I’m almost there I know I need about 6 layers of 1708 for my 1/4 “ l fiberglass. Can I do all of the transom first or I’m I better to lay one or two rows all the way around the transom and stringers so I don’t have a large sectin of 6 layers underneath the next section.
Drivewayboater2
I believe should finish the transom first. all rebuilds I’ve seen have the transom completed and then lay up the stringers to the transom. Structural integrity for the transom assembly is priority.
ltfella
Have 23’ wellcraft coastal I/o. Can I lay 6 layers of 1708 for my 1//4 inch or should I switch cloth between layers if so what kind. Redoing my whole inside transom
jbcurt00
Have you read thru
Lots.of helpful info in here, take a look around
