Re: 1984 Bayliner Capr 1950i, Volvo Penta AQ125A Resto
Thanks everyone!
rykersdad1: Yeah I wish I had been able to do the bearings too. But I didn't have experience with that type of thing before, so I figured it's probably best to leave the worn in ones than try to screw up putting new ones in. Do they look very worn out to you?
And I'm glad you found the pdf files helpful! If you plan to use them keep in mind you may need to adjust the measurements a little (mainly just the height and width of the backrest piece) because your deck may not be at the same height as mine is. Keep notes on how the old structure was put together as you disassemble it. Also, the design isn't exactly the same as the old one, but it's pretty close. The openings under the seats are the correct size for the ice chest insert to fit into.
I've been lightly thinking about how the sound system is going to work out. I figured I would put two speakers in the front storage cavities facing towards each other, and two in the back, probably in those side storage things under the window. I should have run speaker wire as I was building so they would be hidden, but I think it will be ok to run them up under the cap along the perimeter.
mrchev: Yes, like rykersdad1 said there is foam under the deck along the sides, front to back.
I suppose which one you choose to fix up depends on your personal taste, but I would think that the cuddy cabin boat would be a little more difficult to work on. The structure on this boat is pretty simple, and everything is open.
proshadetree: Went by your thread and you did a pretty good job on your transom! I'll be looking forward to seeing posts about your new seats, I'm going to be headed down that road soon too.
