1984 Baretta rebuild (Splashed Aug 2024)
Zyen
hello all. after reading all the other resto/rebuilds, i finally have to post mine....well, what i have so far.
for starters, after patching what i thought was a hole, and with a little prodding, i decided there's no way "it'll be ok for another season...".
i mike said my boat was telling me it needed a resto. best i can do is rebuild, as i have no clue what it originally looked like, as the damn cap has been cut all the way around.
so...i'll post a few pics of what i've done already, but im not posting all 100 or so of them.
as stated in my "is this a hole?" thread, one of the PO's cut thru the stbrd stern hull doing who knows what.
here's the pic under carpet.
under that i found this......
the white 'power' looking stuff is where i was grinding from outside....it's foam dust.
and under that i found this.....
yes, those are 3" wood screws, and yes, they DID puncture the fill hose.
that bare spot in the fill hose is where i grabbed it and the outer jacket just pulled off like rotten skin.
that "fire retardant jacket" now has the properties of a nasty latex glove.
and it's all soaked, but i cant tell if that's from the WONDERFUL glass job or all the effin holes in the glass. 🤦
oh, the whole thing was put together using staples THRU THE DAMN GLASS!
no wonder there's hardly any wood left.
Zyen
Re: 1984 Baretta rebuild
and, like everyone else, i have some BIG help removing foam. :D
after removing foam (for 3 days so far) i found why the bow has water and rotten wood....
this is the inside of the bow eye.
not sealed whatsoever, and using carbon steel nuts!
gotta love rust and rot!
the foam count so far....
the current state from midships to bow.
oh...the whole thing looked like this when i pulled carpet. everything was cracked.
after seeing this, the decision was made....gotta pull deck!
will post more later. gotta get to bed.
g'nite iboaters.
Trooper82
I see you got the thread started and pics! Will be following your progress. Nice looking boat too.
Woodonglass
A small flat nosed shovel works well on foam removal.
GT1000000
Howdy ke5jro,
Glad to see you started a resto thread...Sad to see you started a resto thread :eek:... Amazing how a couple little holes can turn into a complete re-do...
Any how, the guys here will definitely help you through this traumatically fun experience and you will end up with a better than new boat...
I'll be tagging along to cheer, support, and harrass as much as possible...
Have a very Merry Christmas and a Prosperous and Healthy New Year!
Best Regards and Best of Luck,
GT1M
Zyen
... a couple little holes...
lol.... a couple thousand lil holes! :D
Thanks GT1M, and Merry Christmas and Happy, Healthy, and Prosperous New Year to you and yours as well.
Thats great! You are more than welcome anytime, and i'd even go so far to suggest you add "advise" to that list, too. :)
allan
Zyen
got a lil bit more done yesterday afternoon in the bow.
of course i have more rotten wood. :rolleyes:
so, that concludes the deck removal.
now comes the rest of the foam, and then the stringers, and then i'll be able to start cleaning the hull.
somewhere in there i'll need to remove the motor to get the rotten motor mounts out.
will update as i get more done.
Merry Christmas to All!
allan
Zyen
More foam out today. only had about an hour, so i didnt get much done.
only have a lil bit of foam left, and then the stringers come out.
i think im gonna change both dash panels while im working on it, too.
then, i found an original brochure, and realized most of my boat is original.
really suprizing. :)
till next time.
bear_69cuda
Good work on the demolition boss! Merry christmas! She will be one fine boat when you're done. Boat has great lines!
Zyen
Thank ye! Merry Christmas to you as well, a few days late. :)
She will be better than new, for sure. i'll actually waterproof the wood, whereas the factory didnt. ;)
I love the lines of this boat. that is what caught my eye in the first place.
as a side note, it's been raining here for the last week or so, and i havent been able to get anything done.
i dont mind the "cold" (45-50f), but i dont like the cold+rain.
more to come later.
Zyen
hello all.
last weekend i realized just how much the bow was flexing while i was removing the rotten guts.
based on that, i decided to remove the engine and build a cradle for the boat to hold it steady.
the engine would have to be removed anyway to rebuild the mounts, so today i started working toward that end...
i was allowed to purchase a new chainfall (yay!! i've been needing a new one), which worked perfectly.
engine hanging while boat was moved.
engine sitting on it's new mount
engine sitting in it's winter home. (will be covered)
will be starting on the cradle tomorrow.
Friscoboater
Great to see such awesome progress. Are you going to change over to a Mercruiser drive?
umtnman
Brings back memories of a couple years ago when my 1989 Beretta had a small soft spot. Ended up replaceing almost all the deck and some stringers. I wish I had pulled the motor out at that time. Just pulled motor out this summer so I can rebuild motor mount this winter. Looks like you are having fun. Good luck with the rebuild. I will be starting a 1968 Starcraft bass boat total restore in a week or so.
Trooper82
Dang Allen, you are tearing the demo up! Alot of your pictures look eerily familar. I see you got the same hoist I did. Did you find it was twisting your chain the closer to the top you got?
Troy
captmello
Nice to see another Baretta being brought back to life. I look forward to seeing your progress.
JaSla74
Looks like you're off to a great start. Brings back a lot of itchy memories when I restored mine. I guessing your transom fared as well as the rest of your deck. Godspeed
Zyen
hey jay. you are my inspiration man (along with a few others). without your videos and info-packed rebuild thread, i dont know if i would have even tried this. thanks so much. :)
as for merc, probably not. i've known a few ppl whom had good luck with omc, and i'm quite familiar with them, so im sure i can keep this drive reliable and smooth. i have already rebuild this one, new bearings, seals, shift cable, wp impeller, and its quite smooth, no noise, shifts great...and i've always liked omc...they raise a lil higher and turn a lil tighter than merc. i know it dont make very much difference in the grand scheme of things, but its another excuse for me to keep it. ;)
yep yep...small soft spot. thats how this started, too. lol oh, yeah! im having a blast with this. learning a ton, too.
i'll be watching for that starcraft rebuild thread. thanks.
Troy
im trying to Troy. lol i was hoping to get all the rot out by new year. still got a ways to go, tho.
yeah, i noticed that we have same hoist. i like it. i didnt have any problems with mine.
before you put a load on it, make sure the chain is straight. these little ones aren't bad. i use larger ones at work occasionally, and when those chains twist, things get nasty.
thanks capt. i look forward to making progress! ;)
actually, the deck fared better. i found multiple voids in the transom few days ago. will know more when i get it on the cradle and resume the demo.
thank you.
Zyen
started building cradles and removing boat from trailer today.
was so much easier than i had anticipated, too.
first, build cradle for stern....
i figured it would be easy to lift the stern off the trailer to assist in removal.
this pic also shows where the glass pulled off the motor support.
port side has same problem.
stern lifted and secured, ready to pull trailer from under boat.
with the chainfall holding the stern, i was able to lift the bow and walk it off the trailer.
it worked out very well, with hardly any weight on the bow.
boat off trailer. using the 2x4 and level on top to keep boat level.
boat off trailer and sitting comfortably on cradle...so far, so good. :)
used a tie-down strap to lift bow to level out and measure for bow cradle.
started cutting wood and building bow cradle, then it got dark, so i had to stop.
more to come later.
