1979 Starcraft 18 SS Here we go again!!
dozerII
Re: 1979 Starcraft 18 SS Here we go again!!
I can't believe it a plan actually worked out, got the trailer parts sprayed this morning. Now the bugs are having fun perching in the wet paint. "O"well it's a trailer.:)
Glen
jasoutside
Man, you made quick work of that trailer Glen, looks really sharp!
dozerII
Thanks Jas, ya I have to make use of the time when it is available, next week the sun is supposed to shine so it will be time to tackle the house paint job.
800th post
Glen
Woodonglass
Honorary Supreme Mariner
Dozer, Nice Paint Job!! I'm Hoping to Paint my GLASSER with Pettit and the Hardener this week if the Rain stops. I can only hope she turns out 1/2 as good as yours!!!! Again, GREAT JOB!!
Bighoss
Wow!! Dozer, please come paint my boat! Now anything I do will disappoint me after seeing this.
MichaelP
Nice progress. The hull looks professionally done. Hull envy over here!
dozerII
Thanks for the compliments guys. The pictures don't show the imperfections in the job, but I must say the Rusto made it easy to get good results.
WOG I hope the rains quit for you to get your painting done.
Big Hoss, that would be some kind of a comute from here 3400 mile round trip:eek:
Thanks again
Glen
Bighoss
Might be worth the trip, except I could only pay in American and you might lose money in the deal.:)
dozerII
It has been a lot of years since our $ had extra value compared to the Greenback.
Made a little more progress this morning. Got the trailer partially assembled.
sprintst
Nice work. That thing looks better than new.
dozerII
Thanks Sprintst, I didn't go the sand blast route, wire wheel and sand paper, it is far from perfect but at least all the rust is gone.
Wouldn't know it, as I was putting the trailer back together yesterday, I was looking for the bow post. I forgot I had taken it off around the end of the shop and laid it on the ground. It had started to rain so I pulled the trailer inside to finish disassembly, well guess what didn't get sanded or painted, DUH
I also have to figure out how to convert this trailer to bunks with keel rollers from the way it was before. The wobble rollers that were on it caused lots of damage to the bow area. The first photo shows the old roller set up with the short bunks. I would like to add another keel roller on the rear cross member, and two long bunks? What does everyone think.
Glen
dozerII
Bowpost classic, I do dumb stuff like that on a regular basis:rolleyes:
I'm thinking that you'll need to bolt up that rear most cross member from your original set up and then grab 6 of these guys...
http://www.iboats.com/Seachoice-Swi...098739380--**********.597888681--view_id.3044
A pair of 2x's and 3 keel rollers would finish it up nicely:)
Thanks Jason, I put six of those brackets in my cart just to check the shipping and for $18.00 worth of parts they want $29.00 to ship, NOT, I will have to come up with a bottom feeder method.
EZ, thanks for the photo link, that is the set up I want. In my photo I don't have the rear cross member installed yet, but will have to build mounts to hold the bunks off of it. The only problem I can see is the old wobble roller set up over hung the back of the trailer by a foot. I will have a total of four keel rollers under it.
Glen
dozerII
As I mentioned in a previous thread, I have lots of extra holes to fill on the transom. The boat had a live well that I am not putting back in, so there two large holes at the bottom of the transom, one for the pump and one for the drain.
The way I fixed them was to take aluminum sheet stock, 1/4" for the smaller of the two holes and 3/8" for the other. I chucked up a hole saw in the drill press that is 1/2" bigger in diameter than the hole to cover. Cut out two washers for each hole. I then put a 1/4"x2" bolt through the center of the washers and run a nut down to tighten it to the bolt. Then chuck the bolt in the drill press and using a file I radius the outside edge and smooth everything, then clean them up with fine sandpaper. Mark the holes in the transom 1/4" outside the edge on one side and the top or bottom then put a small center punch mark on these,( stops the marks from rubbing off with the 5200). Make sure the hole has no burs inside or out, clean with fine sandpaper on the contact area. Put a little 5200 around the head of the bolt and put it though the outside washer, then put a liberal amount on the inside of the washer, have a helper do the same to the inboard washer then intall them in the hull, sanwiching the aluminum transom skin between the two. Tighten the nut on the inside real tight keeping the out side washer lined up on the two small center punch marks. I then use permanent lock tight and double nut the inside. Should be a life time repair.
PS I also Sprayed the washers with Self etching primer prior to installation to eliminate any over spray.
Glen
dozerII
I'm back to working on the trailer. I plan to run my bunk boards on edge, because of the overhang at the back of the trailer, I think this will give them considerable more strength, as a 2X4 on the flat has none.
What are your thoughts?
Glen
ezmobee
Agree. As you saw in my picture, my transom falls like right on top of the rear crossmember and bunk brackets so no additional strength was needed. If you've got overhang some more support is needed.
jasoutside
I took a photo of your trailer over to my boat architect - he and I had an idea. Use your old roller bracket (in blue) and mount your bunk board flat (in red). He and I both like the additional surface area for the boat to rest on.
Here is the drawing he made for ya Glen...
He had that drawn up just a few hours after I gave it to him, he's great. Very impressive I know. I'll pick up the tab on his services.:)
Just thinking out loud, eh:D
dozerII
Thanks EZ. That is kind of what i was thinking, I did most of the design last night while I was sleeping, but had to reconsider after seeing Jasons drawings.:D
dozerII
Thanks Jason, Here is what we came up with after 6 hours of sleeping on it. It is real strong and only took me 9 hours and then i had to re-think everything after seeing your drawing.;)I just have to get rid of a little more of that ugly Yellow paint.:facepalm:
Glen
