Mikeopsycho
Thread starter- Joined
- Feb 6, 2014
- 738
My nice new water tank,
Oh-oh, all is not well. Ran into a couple of problems. First, the tank was supposed to have a maximum height of 12 3/4", but it ended up at just under 13". You guessed it, it's a tad too tall. Partly my fault for not allowing more leeway, it would have been better if I'd asked for 12 1/2" max height (even at 12 3/4" it would have touched the bottom of the floor at the forward end), and partly the fab shops fault, after all it is taller than I requested. No big deal though, I'm going to bring it back on Monday and they'll remove the top and cut it down to 12 1/2" height and weld her back together for me. They knew it might be a problem when I picked it up.
The other problem is I didn't allow quite enough room to make the waterline connections (Pex). The solution is to steal an inch from the gas tank compartment, I had allowed 2" extra for the gas tank but I can get by with 1" extra. So I got out the tools and cut out the forward rib support for the gas tank floor, Once I get the bulkhead in it'll still be a bit tight but the crimping tool will fit.
