Okay another update. I don't know what's happening, but I worked on the boat again today. Hope this keeps up.
The weather was again in the mid 70's today, so I hand sanded the hull with wet 400. And boy does that hull feel smooth now. BUT, I still have sand throughs AND those pesky pin holes. But I have a new idea to fix them. Instead of using spot putty, and/or rattle can spray primer to try and fill them, I am going to mix up some serious two part primer, that I sprayed twice now on the hull, and use a small paint brush to see if I can fill those pin holes for good. Seems spraying isn't filing them up for some reason. Almost like it avoids the pin holes. So I will force catalyzed primer into them and fill them. Then wet sand and tape off for paint. We will see.
Here is a picture just after I finished wet sanding with 400. Yes it looks very shiny, but that is because the water hasn't dried yet. But the finished gloss should equal that or better.
Another shot. You can see the sand throughs as well.
And a shot from the transom looking forward. And more sand throughs
The sand throughs don't bother me as much as the pin holes. With quality paint, sand throughs will cover without issues, but the pin holes won't. I am still contemplating if I want to shoot another primer coat after I get the pin holes filled and then wet sand with 400 again. Maybe spot primer and wet sand. I really haven't decided yet. Hopefully more to come if I can keep at it until finished. Crappie spawning season is just around the corner...again!
