Kainon
- Sep 13, 2009
- 608
Re: 1976 22' Starcraft Islander Rebuild
Hi, I would have mentioned this a little sooner, I've been offline for a while.
I have a couple concerns about sealing the transom wood in Epoxy.
1. Unless you are installing an outboard, once you cut the hole for the drive you'll need to re-coat where you cut.
2. Any hole you drill or attaching things to the transome ( like inner screwholes will need sealant. Else moisture will get in.
One thing I did was to put some 3M 4200 & 5200 in a few places along the channel at the bottom.
I also found I had a hole right at the channel the hole couldn't be seen from the outside but I'm sure thats where I had a leak. be sure to check for screw holes where pitots and transducers were.
I also had a problem when I cut a little to much off the top of my transom where the alum panel dipped down, check for straightness and level before screwing (new holes in transom) the alum back down.
Nice work !!!
-brian
Nice work !!!
-brian
