Wrongsyde
- Jun 24, 2010
- 77
Re: 1976 22' Starcraft Islander Rebuild
I am a bit of a nut about pretty wood, so it's always good to see others share some of the enthusiasm!! I think you'll really like working with that stuff. It may be a tiny bit more brittle than new because of its age for milling and sawing purposes, but you probably won't really notice during the boat project and it still has full strength and integrity. Its fine grain and evenness makes it a pleasure to mill. Look forward to seeing your furniture... after you finish two boats, a kitchen, your rentals, the other rooms she tells you to do, etc!
Consider using over-sized holes for attachment screws with washers, or other means of letting the wood move. If it's bolted tight to metal, it will crack heart-breakingly soon. And I'm sure you know, use Titebond III for the glue-ups! Let's see the ideas for cabin wall!
Thanks for the compliment... I too tend toward clean functional furniture design. This one's legs were inspired by a "goof-off" practice piece on the lathe that i almost threw away.
Thanks Ben! Yah buddy, I am totally amped about my score!
Yah, I have a few plans for that trailer load. I have a couple of furniture pieces in mind
Yup, for the cabin wall I'll join up the boards with biscuits, cut it to size, slide them in place and install with stainless screws. My plan is to have them removable so I can pull them out every couple of years and re-finish as needed.
Man, your table looks beautiful buddy! Clean, classic lines, like it! Are we calling that Craftsman style? I'm not so much into the fancy stuff, Shaker is my favorite.
