Re: 1975 Starcraft Mariner 18'
Ok a little progress of sorts got up the nerve to dump some water in her this morning kind of nervous about the wieght so started out by lowering the bow and checking that area first. Hooked up the hoist and folded the jack to get her as low as possible.
Had a couple little dribbles on this seam not sure what I'll do here probably try some epoxy on the inside then maybe 5800 on the outside ?? I think Primer and paint will probably seal it up as very slow leak.
Then I raised the bow to check the middle and stern
I found quite a few rivets that need attention despite the generous gluvitizing a few near the bow but most are midship.
I raised it up Higher and checked the stern everything back here seemed fine
I used a jack stand under the back of trailer to keep her from getting out of control on me and filled It with more water until it was over the lip for transom. Then I leveled it back off and filled it until I wimped out. I didn't get it all the way to the crack repair but did hose that area good with no sign of leaking so hopeful. All in all I'm reasonably satisfied, I marked those rivets and I'll rebuck em as soon as I have an extra set of hands available as most are fairly low on the bottom I may slap a little epoxy or JB on to make sure prior to primer and paint. I lowered the bow again and checked it with more water with same results so pretty confident just the little slow dribbles at the bottom of that seam. I did take some more pics but Idk how many boat full of water pics anyone would want to see.
