Re: 1975 Checkmate V-Mate II Restore
Okay, update time. I finally towed the boat down to my folk?s house a while back. I popped the cap back off and fixed some delaminated 1708 that I glassed. I drilled some holes, mixed up some epoxy with some milled fibers and Cabosil added and used a syringe to fill in the areas. After I saw the areas fill in, I taped them off until everything cured. Then I hit it with a quick sand to smooth everything out.
I then trimmed up newly glassed splashwell. Afterwards, I glued the cap to the hull.
To flip the boat, we used a pulley system. I unfortunately didn't take any pictures of this process but I will when we flip it back. Basically, there are two pulleys positioned on the starboard and port side of the boat near the stern and two more near the bow. We raised the boat high enough to remove the trailer and we proceeded to turn the boat with the use of ropes. I removed the bunks off the trailer and ran 4x6's across the trailer to set the boat back on to work on it.
