1974 Starcraft SS16 Restortation
ShoestringMariner
Before I started wiring the boat I was looking at an 8 switch gang panel with USB, Cig Lighter, DC out and and Voltage read out. I also picked up a Blue Sea Fuse Block to run all my components through. However, I did not like the way the gang panel was set up so I re-wired it so I could incorporate the Fuse Block. I also got 2 x bus bars for components that had inline fuses. Such as the USB, Cig Lighter etc.
The fish finder, horn, compass and stereo will all be linked via the Fuse Block so I can take advantage of that particular system.
This is what I have to wire:
- nav lights (done)
- deck lights (done)
- storage lights (done)
- bilge pump (hard wired to the Starter battery with float switch, and manual control switch) (done)
- live well pump (done)
- aerator pump (done, but not connected yet as the live well will be one of the last things I put in)
- fish finder
- stereo
- compass
- horn
- trolling motor (hard wired to the House Battery with 60 amp inline fuse and 8 AWG wire)
Here are some pictures of me mutilating the gang switch so I could get it to where I wanted for my vision of the wiring:
Its seems pretty convoluted at the beginning, but I watched some videos and figured out what I had to do in order to re-wire the thing the way I wanted it.
I took the positive feeds off of the USB etc, and will run a direct line for these to the bus bar with the inline fuses.
Next was to take the positive feeds from the switches so that I can link them all independently to the Fuse Block.
This is the finished stripped down version with the negative feed, and the positive negative feeds for the LED lights on the switches. These were linked directly to the Fuse Block with a 3 AMP fuse. These are the little lights that are on all the time. The main LEDs only go on with the switch is activated.
My diagram so that I could make sense of things. This actually helped me.
This is a diagram of the back of each switch on the gang panel so that I could remember what was what. It helped.
I will post some pictures of the wiring that has been competed in a few days. Maybe with some photos of the lights and what not.
Thanks so much for posting this. I have the exact same components.
FIGMO
Great looking hatches. I'm also right at that hatch-building (and laying-out) stage on my SS. How large did you make your livewell?
Hello mattsteg,
I will get back to you in a couple of days with the measurements, but I think i made it too big. I just finished cleaning out my garage after winter, so I have to get back in there to get the dimension.
FIGMO
Really nice work!!!
Boating is really coming along and you will be in the water shortly!!
SHSU
Hey SHSU,
Thanks for that. It has to be this summer. I can't go five years with the boat in the garage. Its killing me.
FIGMO
Hey Shoestring!
I am glad it helped. I took a fair amount of time reading what others did and then "tried" to carefully layout what I needed to do. I have to admit that the wiring was my favorite part of the rebuild.
FIGMO
Hey Guys,
Some more light pictures. This time the deck lights in the back of the boat.
This is pretty straight forward, not much explaining required. In addition to the lights on the panels, I added some blue LEDs under the gunnels to light up the storage area.
Lots of blue! I am digging the blue theme.
More of the same.
Like like the fact that I can set the colours on the speedometer and stereo head unit to blue as well to match the over all theme.
And the stern.
I have a couple more light shots left to post. Some of the bow. And I took some really blurry night shots. I will do them again now that I have a better camera.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
With all of the nice work on the interior lights, any exterior or underwater lights?
SHSU
ShoestringMariner
Hey Shoestring!
Yeah it shows, totally meticulous work. I’m taking notes!
MNhunter1
Lookin’ great FIGMO! Been out of town the past few days and catching up on all the posts. Love how the deck and hatches all turned out and great job with the lighting.
FIGMO
Hello mattsteg,
Hello again mattsteg,
I have the dimensions and some photos. The overall length of the livewell is 36", with 8" on the end for plumbing and 28" for the livewell proper. The height is 11.5" with a depth of 15.5". The area that is 8" was also meant for ice to cool the water circulating through the aeration pump. The idea is to have about 6 to 8' of hose circulating the water through the ice.
I think I will have the livewell remade to make it about 1" lower in height, 2" narrower and 2" shorter. That will put me out about 300 bucks...
Here are some pics:
This is the livewell in the aluminum supports with 1" insulation surrounding the livewell. The aluminum frame will get riveted to the deck, and the wood side panels will be riveted to the aluminum supports. I will have to assemble the livewell in the boat starting with the aluminum supports anchored to the deck and then build up. After that I will be able to place the livewell in the supports and add the insulation. Last will be rivet the top supports and then add the wood. The top horiztonal pieces that will be against the back and side panels will have to be in place before it gets riveted to the deck.
Shot of the main tank with splash guards.
The plumbing area with the intake hose from the livewell pump. The aerator pump. I have a water proof LED light for the main tank.
The doubled valve with the hoses to the left is for the aerator pump. One hose circulates the water in the well. The second hose exhausts the water out of the well by adjusting the head unit on the inside of the well.
Intake and exhaust fittings
More of the same.
Here you can see the LED light on the left. In the middle is the filler valve. The red spout on the valve can be pushed in or pulled out depending on whether you want the pump to circulate or drain the well. At the bottom is the intake for the pump to circulate the water, and a drain at the bottom.
That is about it for the livewell. Its just too bad that I made it too big to start with. However, I am prepared to bite the bullet on the 300 bucks in order to get a livewell at a size that will work for the configuration in the boat. The good news is that I can resize all of the aluminum supports and side panels as I am going a bit smaller.
FIGMO
SHSU
Hello SHSU,
I thought about adding some underwater lights, but decided that was a bridge too far. No exterior lights either, other than the navigational lights.
FIGMO
Here are some really blurry night shots, but the pics give an idea of what the boat will look like in the dark all lit up.
I'll do some better pictures when I get closer to finishing this project.
That is about it. I am pretty much caught up on the pictures I took last year. Once it gets a little warmer, it will be back at it! I think the first order of business will be the back panel door, and the main hatch in the front deck.
mattsteg
Here are some pics:
More of the same.
Thanks...I'm in the planning phase for adding a livewell of roughly similar dimensions to my SS.
SHSU
Hello SHSU,
lol
Ya, I found I had so many grand ideas but not enough boat for them all. I too did not have any permanent underwater lights. I just have flood lights and a green light I can throw over the side.
Still great work!!
SHSU
FIGMO
lol
Still great work!!
SHSU
Lol SHSU, during the rebuild did you ever think to yourself "we're gona need a bigger boat"
mattsteg
I'm sure that a lot of us alternate between "gonna need a bigger boat" and "gonna need a bigger garage".
Every boat is simultaneously too small and too big. That's why you need a fleet.
SHSU
@FIGMO ,
Yes, all the time, but as @mattsteg pointed out I needed a bigger garage to go that route. Admiral said "NO" and I couldn't convince myself to pay to store it somewhere else.
I just have to drool and look on in envy at the guys with huge shops or work areas to do their boat projects.
SHSU
mattsteg
@FIGMO ,
SHSU
What about those of us who somehow shoehorned 27 ft of boat+trailer into a 24ft deep garage and are still digging out of the mess that created?
Watermann
Very nice work, everything is looking top notch!
y4mUx-QlmUmNRuGNeBC5R1T9BFRlbr8xD7nlCdkdslyyniOVw-kppaIavCE-WCKIHQ_NIfiHktZ4PiuHojCjNk3vVzJ-Oa88BK6ohmh7h-vr-735YNCm8-Pf5RImT4xbZ56cpwBLtoGpIr4zd_g4862TEq6tq7d3s5Ct2nIYDXDUsLCDmYGfaeX8FBTXWwmRPXo
FIGMO
@FIGMO ,
SHSU
I hear you. However, if this goes well enough, I think I will be happy with what I have. Sometimes its nice just to be able to enjoy looking at the big flashy boats, without the headaches.
