Re: 1973 wellcraft 165 sport airslot project w/ pics
wow that transom is the cats meow, you could put 300 hosses on that.
to pre-glass or not to pre-glass,?
I pre-glassed a 4x8 sheet , both sides w/ polyester and mat, then I cut my stringers from the sheet. Saved a lot of time.
I use non waxed poly, no sanding required between coats and it goes off very fast, epoxy is great except for that quality and the expense.
with epoxy I wouldn't bother pre-glassin unless access made it necessary but you're working in the open , you'll save at least a day by not pre-glassin.
your hull looks identical to my chrysler, they ride nice.
