Re: 1962 Arkansas Traveler restoration
Thanks Joe- that's quite a compliment!
Bob- I must have missed or overlooked the wax paper thing- yeh that would have helped big time!
Here is a video on my thoughts on pourable foam and a demonstration on a pour! If the link doesn't work you can find it on youtube under "Mixing Pourable Foam"
http://www.youtube.com/watch?v=yO_oXuP17fE
Here is the foam from the video after about five minutes
[/IMG]
Tonight I got my transom cap fiberglassed. I used two layers of biax.
[/IMG]
One thing I did the other night when I was done foaming was use great stuff foam in a can to spray around the edge of my deck.
[/IMG]
I did this because there was a valley between the deck and the sides of the hull. Glassing in the deck would have been tough because it was a fairly wide gap and dip. So today I cut off the excess and it did exactly what I wanted it to do- to make it some what level so glassing will be easier.
[/IMG]
I also filled all the holes from foaming, my screw holes, and any knots in the wood with a short strand filler.
[/IMG]
[/IMG]
Next I have to sand, wipe everything down with acetone, and then glass the top of the deck! I may not get to that for a couple days though- school work.
I have a question I was thinking about tonight. Do I have to glass the outer transom skin over the areas I filled with filler that I used for my bolts to tighten down the frame I used for my seacast pour? I don't think so but I had to ask.
Goodnight!
