Re: 18' Starcraft SuperSport restoration
I just got back from the PA Fish & Boat Commission where I finally transferred the registration for my boat to my name. I'm all legal now! My bearing seals for the trailer came in on Friday. I have my axle in the truck right now and I'm headed to the RV shop right after work. We'll check the seals to make sure they fit and if they do, I'm headed immediately to the shop of a fellow iboater, john3931, who has generously agreed to help me get everything reassembled. I will be so pumped to finally have this trailer done.
Assuming that all gets done tonight....the plan is:
- reinstall the axle. Probably have to move it a couple times to achieve the optimal tongue weight
- install the new LED light set on the trailer
- fire up the motor again, this time with the lower unit submerged and see if I can replicate the situation where it stalls going into gear. Adjust the idle speed and see if that helps
- One night this week take the boat for a test run
Assuming nothing catastrophic happens....I will be taking the family out this weekend!!!
If those bearing seals don't fit I'm f&*ked! The RV shop took careful measurements though before ordering so I'm optimistic. If they don't fit I'm going to order a whole new axle to get away from all this weirdness. I will probably do that at some time in the future anyway.
Speaking of hail damage.....found out Friday we're going to need a whole new roof on the house. Joy.
