Re: 16' Nescher ski boat complete restore
Thanks, it is really starting to feel like a boat! Tonight (despite the squirrels best efforts) I hooked up all of Max's controls....the steering cable went pretty easy, but hooking up the shifter cable to the control was a chore. The instructions read something like, "position shifter in neutral to access retainer and remove". The "retainer" lock nut, that you can barely get to with an open end wrench.....so after about an hour I got it put together. After that everything went pretty smoothly.
I was tempted to pull her outside and fire up Max, but I need to spend sometime checking over the electrical system....ohming things out....and tying off some "loose ends" that go to things that aren't installed yet. Hopefully after splashing her, I will have the tank issue figured out. That should allow me to get the interior finished up and the swim platforms built.
