16' Nescher ski boat complete restore- SPLASHED!!
archbuilder
Re: 16' Nescher ski boat complete restore
Here is the wiring fix on Max, heat shrink tubing works great for replacing insulation.
Before:
After:
micks110
Master Chief Petty Officer
Arch- how much does it cost to get the trailer sandblasted? I think mine will need that for sure.
Great idea on heat shrink tubing to fix insulated wiring!
jspano
arch
that paint looks soooo good the Miss Morgan should just slide across the water
GREAT JOB!!!!
archbuilder
Thanks Joe!
Mick I think I can get it done for a couple hundred bucks, I should know later this week.
I just gave Max a bath.....now I smell like an outboard motor.....not much else to report today. Just waiting to get the trailer blasted.
micks110
That's funny you said you smelled like the motor. I still am getting wiffs of chainsaw exhaust and chimney sutt. I was cutting pallets today and cleaning the chimney flute out and still smell it.
Mountain_Man
I can't believe the torque! Get her on plane and steer her with throttle changes:D
I like the stripe idea on the trailer. I think that black would be the only thing that would look right on the steps. How about a silver pin stripe around the fender flair?
Friscoboater
There is no mistaking the smell of a 2 stroke. that smell brings back memories from when I was a kid heading out on the lake.
fat fanny
I'm with ya there Frisco I will never forget that smell started when I was young on the MX circuit BellRay and airplane fuel. Arch I can't imagine what that paint is gonna look like after color sanding, Also have you concidered using a little of that silver and red to accent a matching stripe on max.
archbuilder
Bellray, forgot about that stuff! As they say nothing, sounds, looks or smells like a Mercury tower! I think it will look sharp against the silver transom... I might do pinstripes on Max, but I will probably stick with the factory scheme....I like to keep things "period" if I can. I've toyed with the idea of the fender stripe Mountain Man....another thing I'm still pondering. Max looks really good after a bath. I need to give him another one, but I need to figure out the tilt trim wiring first. I need to get it tilted up so I can hook up my wiring harness and scrub up under there. Guess I need to buy a service manual so I can figure that out. I hope everyone is having a great evening!
BobsGlasstream
Hey arch,
Max looks and sounds great.
I still can't believe how great Miss Morgan looks.
I knew it would look good, but she blows my mine.
Glad to see her outside again.
Great Job.
Bob
vegasphotoman
that paint came out phenomenal! great job! and now you're going "all the way" and color sanding...... wow...you will have no arms left after this week! lol that clear sure POPS that red eh!
your Max is awsome........sounds great!:D
mrlassi1
Arch, you have invested an incredible amount of time in your project AND the iboats postings and videos. I read the entire thread over a four day period. My first boat was a Glastron GT150 with a 140 Evinrude. I know you are planning your interior and fuel tank placement so I wanted to give you some input. You have been clear about wanting to keep your boat period. The back-to-back seats shown in the earlier post were like those in the Glastron. Mine were black too and were brutal in the Florida sunshine (I was in Pensacola then). Those curved seat frames were made of plywood and the seat cushions had an aluminum tube screwed to the bottom that snapped into a stainless steel clip mounted in the floor frame.
Getting the weight of your fuel tank forward will help your boat come on plane much faster. A trianglular plastic fuel cell with a Stainless Steel flush fuel fill would be so smart. Put a fuel gauge in the dash too. Your instruments (suggestion only) would be Seedo, Tach, tilt/trim indicator, and fuel.
Ever see a boat trying to plane off and all the passengers moving to the front to help it out - not a pretty sight.
Don't repaint the tower, just touch up the spots that need it. The factory gloss and graphics are classic. Shop around for a SS prop. With all due respect I bet she won't pull more than 19" of pitch. And she (or Max is a he - SMILE) won't be happy unless he's able to run 4,500 to 5,000 RPMs. On one of my restor projects I found a 150 tower with a blown powerhead and salvaged a bullet lower unit, SS prop, trim/tilt system, and a new battery (not sure why the guy threw it in for no added cost - but he did) for $500.
Your graphic idea with the stripe and Nercher are great. As for the trailer, paint it all silver (fenders too) so your red pinstripes will show up. The new LED lights are the way to go. Low maintenance (or NO maintenance) and high reliability - we love that in anything related to boating.
Consider using one of the new gel cell Optimum batteries too. No mess, high reliability.
One last suggestion. My GT150 had the engine controls mounted low on the left side of the driver's seat base. I have never seen a set up that way, but it worked so good. If you pull skiiers much you're always twisting around looking back. Having the controls on the left (and low) makes them easy to access.
You have helped us appreciate your tools, patience and skills. Hat's off to you! What brand paint gun do you have? Is it a top cup or traditional bottom jar style? What about pressure settings and your in-line filter/moisture trap?
I can't wait to see what you do next.
archbuilder
Thanks Vegas, I'm excited about getting her flipped and the paint on the top side. All my friends have now decided that maybe I'm not so crazy! Now that its red and shiny, they think I might have a clue, LOL!
Thanks Mrlassi1. We used to have a tower when I was a kid and ran a 19 on it. Seems it would still make it up to around 5,500. Right now this one has a 13 on it. As for the seats, I'm going to recreate the back to back seats, hopefully I can get some measurements on the originals on the black boat. For now it will have the tanks in the back...running short on $$ to finish before summer. I can always add the bow tank later.
wa_ssv197
You can always run to Sears and buy the sandblaster tank and do it yourself.
I have done that on another boat trailer, and the only bad thing was the amount of said laying around afterwards.
ogrealan
Archbuilder, after reviewing your progress and boat selection I have finally decided to attempt the exact same rebuild as you but on a 1970's 17' Marlin Aquarious (Haven't seen any out there) one difference is I do have the original back to back seats which I am updating the upholstery. If you would like I will take pictures and measurements so that you might be able to duplicate the design. I'll work on getting pictures this weekend as I need to drag the boat out of storage and start getting to work. I'll try to post a restoration thread as I go with pictures and see if I can do half the job that you have. Boat looks great keep up the good work and inspiration.
archbuilder
Thanks Ogrealan, any reference info would be helpful and appreciated. I'm looking forward to seeing your thread!
On the sand blasting, I found a guy who will do it with silica today for $140. I've spent way too much quality time with a sandblast hose...for that price they can have fun with it! Looking at the weather, its more or less going to suck for the next week or so. Its not supposed to rain tomorrow, so I may see if they can get it done for me. I also need to order the bunk carpet and pick up the paint. I'm starting to feel like a stimulus plan!
archbuilder
Well I finished stripping the trailer tonight, its ready to be loaded up and taken to the sandblaster (still need to pull the axle, but I'll do that right before I load it). Its funny how you spend all that time bolting stuff on as you are fitting it...then have to take it all apart! I was questing the wisdom of all the lock nuts as I was taking them off in 30 degree weather! I'm going to try to schedule the sand blasting tomorrow. I think I could pull Miss Morgan out of the paint booth enough to get the trailer in. I had planed on shooting it outside, but that isn't going to happen soon given the forecast. Till I get it painted I'm pretty on hold on the boat. I also ordered some more carpet samples, should be interesting to see what I get.
archbuilder
Does anyone know if you can upload PDF's to photobucket? I printed my paint booth plans to scale, and wanted to post the with a link to photobuck. The files are too big to post here.
BobsGlasstream
Hey arch,
I looked on photobucket for pdf files and did find some, so you must be able to. I'm not sure how, but there are some on there.
Bob
sprintst
Damn man. Nice work. That hull is so smooth you can probably row it out to 40 mph
