16' Nescher ski boat complete restore- SPLASHED!!
archbuilder
Re: 16' Nescher ski boat complete restore- SPLASHED!!
Today I set out to finish the swim platforms, didn't even get close! This morning I cut out all the gusset pieces and finished my jig to weld them up. At lunch I ran around and picked up some hardware and more stainless welding wire. I did quite a bit of practicing with the stainless this morning.....I got a lot better, but I'm still not totally satisfied with my welds. Oh well its always a learning curve. After getting the jig built and the gussets cut out I was ready to weld away. I figured it might be best to polish everything, then touch up the welds later given the geometry....good thing I did. I sanded one piece with a DA, 40, 80, 120, then went to wet/dry 220, 400, 600, 1000, 1500 and buffed...this is what I ended up with.
I was not happy with the pitting at all, which was part of the finish from the mill. I sanded the hell out of it again, but the results weren't much better. I finally called it a night with the idea of getting up tomorrow and buying some more industrial strength polishing equipment....then I called my freind Don. He was out but one of his friends was at his shop working on a project. Don's shop is a normal really, really, really nice dream home wood / welding / machine shop on industrial steroids! He has a drill press that weighs 20 tons..... I won't even go into all the other goodies he has! Any how his freind said that Don has buffer that should make quick work of the pits. So I'm going to try to arange to stop by there tomorrow and buff out the parts before I weld them up.
I did get my passenger seat oh sh*t handle installed. I need to take it back off and 5200 the holes, but I will do that when I install the swim platform brackets.
I also drilled for the fuel gauge, naturally I didn't have all the hardware I need to install it...I'll try to pick that up tomorrow.
I did pick up some 5/16" couplings and fender washers. I'm going to weld the washer to the coupling, drill the glass blocks to accept the coupling / fender washers....then epoxy them in from the bottom side. I should be able to thread in all thread or bolts from the top. That solves a lot of clearance issues with the new gas tank.
I hope everyone had a great Sunday!
Friscoboater
I am right there with you about missing goals. Something always sets me back.
fauxmeister
Arch, the platforms look great! Hope you have a great Mem. weekend!
Last Mohican
I know it is kinda late in the game but have you considered flag brackets instead of welding square tube? That is what I had made for mine with stainless backing plates inside the transom. All you need to make them is a break and some stainless sheet. I used brass inserts with a dab of gorilla glue in the bottom of the steps so there are no screw heads on the top of the steps. I used loctite and lock washers on the bolts into the steps. They have survived 1.5 seasons without coming loose.
(Clickable thumbs)
archbuilder
Thanks for the thought, I thought about having some broke like that. It would have been easier for sure......but I wanted a little heavier bracket to used as a tie down point for the trailer straps. So far I have been just tying straps to the motor mounts. The brackets are actually 1/8" x 1-1/2" bar stock. I modeled them after some on a friend's tournament boat. I guess I at least learned to weld stainless, lol! Heading over to my friends after lunch, hopefully his buffer will take care of my problems. What gauge did you use by the way? I'm wondering if I should have stepped up to 3/16" since I'm using it as an attachment point.
Last Mohican
Ah. Now I can see that is flat stock. It's been a while since I had them made. They measure about .077 think so I am guessing 14 gauge. Hope the polisher works out for ya.
archbuilder
Ok just a quick update while I absorb a beer.....let me state the obvious....stainless is harder than hell, which makes it durable.....and also harder than hell to polish! I opted to buy some buffing wheels for my bench grinder rather than drive up to my friends......I also finally took my 5" air grinder to a scrap with 36 grit on it, hit it with 40, 80, 120, on the DA, then wet 220 and 400, then the heavy compound on a cycle wheel....then a the light compound on a spiral wheel. It came out pretty good, but there are still some sanding scratches from the DA.....back too it, I might get this stuff polished today...then its weld and polish the welds, long process!
archbuilder
Well I finally called it a day, for some reason I wasn't feeling too good. I did get all of the bracket pieces ground down with 36 with the 5" grinder, 40, and 80 with the DA. I started with the 120 on the DA, but went ahead and finished up a couple of pieces, wet sanded them with 180, 220, 400, 600, and 1000....then hit them with two buffing wheels and two types of rouge. It isn't perfect, but has a good reflection.....there are still some scratches, but it looks great from 5' away.
I also got the thinking, most of it will be under water anyhow, lol! A few more hours of sanding and buffing and I should be ready to weld them together....I'm hoping I can just dress the welds and polish them. Guess we will see!
Woodonglass
Unless you're wanting to use em for mirrors to SHAVE with underwater, I'm thinkin they're good to go!!!!!
As, Always NICE WORK Arch!!!;)
Arch... If you ever bring her back to Stillwater and put her in Lake Carl Blackwell, let us know. I would love to see her in person!!
archbuilder
If am up that way I will let you know Cowboy. Wood, that is the funny part, you won't even see all my handy work unless she is on the trailer, lol!
archbuilder
Ok, great news.....I'm blowing off working on her an the place at the lake this weekend and getting her wet! No tank yet, so to hell with it! I hope everyone has a good weekend either working on their projects or getting them wet!
Triton II
You too Arch. Hope you and she enjoy getting wet together! :D
TII
Last Mohican
I'm with ya Arch. I hope to hit the water with the Rebel Sunday to test the new jet pump. I managed to add a window to the bowl last Wednesday night. I was making a wide open run and it just quit pulling. GPS latched at 58.4 MPH so I guess that is the speed it let go at. I pulled the pump out of the cruiser since the Rebel is entered in a Pontiac car show next weekend. Once the replacement bowl arrives I'll put the Rebel pump back together and put it in the cruiser.
(Clickable thumbs)
redfury
Nonsense! JB weld that sucker back together and you'll be on the lake in 24hrs. :D
Whaddya suppose knocked the window into it? a rock?
Last Mohican
I was in water way to deep for it to be a rock. My initial thought was a turtle or a stick. Upon further inspection, after disassembly, there is no evidence of anything going through it. My guess is it was fatige from being 37 years old or it just could not hadle the awesome power of the Pontiac 400. LOL.
archbuilder
Sorry to hear about the pump Matt, hopefully you will get it back together soon! Miss Morgan ran like a top.....I forgot how well Max pushes her around! She has one hell of a hole shot! She ran 54mph with a 17 on her, I'm thinking about going to a stainless.
archbuilder
Ok I spent 3 hours sanding the stainless tonight...I think I can finish up the sanding in about 3 more hours...hopefully I can do that tomorrow night....then its weld everything up...then back to sanding the welds and touching things up.....If I mention polishing stainless again, someone slap me! :facepalm: The gas tank came in, here is a somewhat blurry picture of it...
I didn't have time to check the fit tonight, but the quality is great! SP Sheet metal built if for me, very nice work! Hopefully it will go in without too much of a fight, after the stainless I'm ready for something to go smoothly!
Triton II
Good looking tank Arch, hope the installation goes smoothly! :)
TII
ezmobee
That tank looks very well built. You should really polish it :p:p
