I thought about that too but, I bought a big ol swim platform to hang off the back though thats been sitting in the shipping crate this whole time. Plus this boat has a bad tendency to wander at low speed; do you think putting an outboard further out might make it worse?It's not too late to make this project an outboard conversion.![]()
Would you install pickups and a transfer pump? How would you setup a fuel fill for three seperate tanks?Boats sit and run bow up, I would put pickups toward the stern
I've owned 2 SRs AJs and a Proline 2950. I never could understand why Mfgs didn't add limber holes to drain possibly saturated foam. I never had SR issues with the crap you exposed. Transoms are another story. Proline mfgs should be in prison for fraud. But my PL 2950's stringers were much easier exposed and repairable. The transom was crap too. Older Grady Whites are rot nightmares as well. You seem to have done a lot of work. Me too! I assume (w/o reading your War and Peace) that your transom was in as bad of shape. I hope you have time, money, and good health for this project. My health failed. But, hell, I'm 77 years old. Good luckHello all,
I would like to share my disappointing story and get some of your thoughts. I bought this boat last year. When I bought it, I noticed the owner had replaced the cockpit seats with some after market back to back louge seats; none of the screws were bedded and none of the old seat holes were plugged. I knew I would have to re-core the mid birth ceiling where the seats sat on. I figured I could takle that easy enough. Well that changed today; the can of worms has been opened and the water from the ceiling leak has turned into stringer rot. I have dug out all of the rotted stringer so far and plan to scarf in new stringer and deck sections with half inch marine grade plywood. I am a little confused by the method Sea Ray used to splice the original stringer. They made a long taper joint in the stringer and used a butt block to connect the two, but the stringer terminates about 16 inches away at a bulkhead. I would like to glue in the new stringer at that termination and scarf in at the other end. Could I scarf in over Sea Ray's joint or should I just use Sea Ray's joint method to make the splice? A scarf would be about a 6 inch joint and a Sea Ray splice joint would be about 48 inches long with the the removal of another bulkhead.View attachment 414964View attachment 414965View attachment 414966
I wouldn't have lines and valves connected to transfer fuel from one tank to the other, or have the lines between tanks low enough so they self level, just doesn't sound safe.Would you install pickups and a transfer pump? How would you setup a fuel fill for three seperate tanks?
