Engine misfires after rain storm
kbryant
Hi
I have a 2011 Tahoe Q5i 4.3 MPI. Runs great at idle - no issues starting - under a load it misfires and backfires after sitting in a rain storm. I had this issue before about 2 years ago. Shop said it was a loose battery cable. Worked fine for 1 1/2 years until last week it sat in the rain. I’ve just replaced battery and fuel filter and check pickup tube. Anyone else have this issue and some ideas where to begin.
kbryant
Do you think it will continue to do the same problems after I change those out?
Scott06
No that why he suggested to replace. Typical symptom of misfire when wet is bad cap rotor and wires. If you don’t know when they were replaced start there. Check your timing and spark plug condition as well.
kenny nunez
Does your engine cover allow water to land on the distributor? If so water is getting inside the distributor body through the flame arrestor screen on the side. You will have to rig up some type of shield to flow the water away.
you should have the crab cap..... those are a replace nearly every other year regardless type of thing. because the cap breaks down internally.
kbryant
Hello,
Here is an update - I replaced the Cap, rotor, plugs and wires, pickup tube and fuel filter. Boat ran great for about 10 minutes and now doing the same thing ither than it is not back firing anymore -- Just will not go on a load. I have ordered a new Ignition coil and see if that helps. Any other thoughts on what it could be? Thank you again for all the help.
nola mike
Any water entering your fuel system? Are you sure this is an electrical misfire?
Scott06
Or my favorite Easy Go to " throw a timing light on a coil wire test"
i have become fond of the spark gap tester for this so you can see how strong the spark is vs just there.
ten or so years back went through an older evinrude outboard. Last thing I replaced was the coils - this was after fuel pump, carb rebuild, points and condensers... I had spark showing but it was weak as hell, ohm'd the coils and it was one of the few times I actually had a bad coil (2 in 40 years of wrenching). Both coils were way out of spec on ohm test but it still ran just not for chit when you hammered down
nola mike
Yeah, ha ha actually going through that right now with my Merc. Has spark with the light but weak on a gap tester. Still a good first test I think, and if it's missing you know it. Also guessing that a weak but not absent spark is more common with a stator driven ignition, multiple places to weaken. A 12v system like a TB more likely to either have it or not.
Scott06
Not sure on the stator driven set up but this 1974 Evinrude is a coil eater. I went through everything but the coils as I saw spark on the plugs, did the coils last which I may have been able to skip the carb rebuild.
When I did my repower and used the gap tester on the TBV then I saw what a really good spark actually looks like, so I learned something. I checked all my engines when running good to get a feel for what the spark should look like on that engine
nola mike
Yup, I also assumed carb initially and rebuilt it yet again. If you don't have one for your 'rude (and if it's a CDI type system), definitely get a DVA. Nearly impossible to troubleshoot properly without one. The merc also has a spark at the plug, but very weak. About to (hopefully) fix it with a new trigger...
kbryant
Well, another update. I finally have given up. It’s going to the shop. I can’t figure it out. This will be the last inboard motor I buy.
kbryant
Thank you everyone for your time and advice
jimmbo
High Humidity, which can happen when it rains, can wreck Havoc on Plug Wires. It can also help create conductive Paths on the Ceramic Insulator of the Spark Plug, especially if that Insulator is cracked
Outboards can be just as finicky, the newer ones, with all the Electronics, even more so
kbryant
Quick update: I replaced ignition coil and she runs good. However: it now does 3 fast alarm beeps every minute. Temp garage at 160 and oil at 40. No lights on. Anyone have an idea where to dig into this now?
kbryant
Anyone know what the 3 quick beeps mean every minute? All gauges are good - no enigine lights. Boat runs good
