Engine misfires after rain storm
kbryant
Hi
I have a 2011 Tahoe Q5i 4.3 MPI. Runs great at idle - no issues starting - under a load it misfires and backfires after sitting in a rain storm. I had this issue before about 2 years ago. Shop said it was a loose battery cable. Worked fine for 1 1/2 years until last week it sat in the rain. I’ve just replaced battery and fuel filter and check pickup tube. Anyone else have this issue and some ideas where to begin.
matt167
New distributior cap, rotor, and wires with di electric grease in the connections.. see if it comes back. It probably won’t
kbryant
Do you think it will continue to do the same problems after I change those out?
Scott06
No that why he suggested to replace. Typical symptom of misfire when wet is bad cap rotor and wires. If you don’t know when they were replaced start there. Check your timing and spark plug condition as well.
kenny nunez
Does your engine cover allow water to land on the distributor? If so water is getting inside the distributor body through the flame arrestor screen on the side. You will have to rig up some type of shield to flow the water away.
you should have the crab cap..... those are a replace nearly every other year regardless type of thing. because the cap breaks down internally.
