Engine misfires after rain storm
kbryant
I did just put on a new ignition coil. Could it be that the engine doesn’t like that one?
jimmbo
Non-critical Sensor fault, however... Connecting a scanner to the Engine Diagnostic Port, is what needs to be done.
Meanwhile, try checking for Low Gear Oil level, Water in Fuel Filter.
kbryant
Ok that you. Is there a picture anyone could share where the gear lube sensor is located? I cannot thank everyone on here for your time and advice.
Captain of the Double G's
integrated into the gear lube monitor reservoir bottle mounted inside the engine compartment. It uses an internal float switch to trigger an audio warning horn if the outdrive gear lube drops to a low level. [1, 2, 3, 4, 5]
