Can the base of engine work? Two to bolts under engine are rusted and can
liusigou
My boat engine is 2.5L, 120H Mercruisier. Coupler was wipled and bellow house is leaking Today I removed the four bolts and found two bolts under the engine are rusted. I can but two bolts but the base can work with the two bolts.? How can I fix it?
dubs283
No clue what's going on here
Dont mean to offend but is English not your first language?
liusigou
The bolts are loosen and cannot work. and the boat met big wave and moved which caused engine moved and the coupler was wiped.
dubs283
Not. English is not my first language. everything are professional words.
Understood, but the syntax of your first post was off
The picture you posted shows the two rear mount bolts. They secure the flywheel cover (engine) to the inner transom plate. I am to understand that either the nuts held in place at the transom plate are rusted/gone or the mounts the bolts pass through are gone?
The smaller, lag bolts most likely hold the fwd mount to the boat. They look like there is stringer/mount area material that is rotten and stuck to them
Either way your issue may be more than just mechanical/mount related. There could be transom/stringer rot
  • Like
Reactions: KJM
Rick Stephens
The lag bolts for the front mount have nothing to bite into. You will need a way to rebuild that crossmember so it is solid again. If the lag bolts won't screw in tight the motor moves and the coupler gets destroyed.
liusigou
Thank you Rick, Is it easy to rebuild crossmember? How to do it?
achris
More fish than mountain goat
If you have fibreglassing experience, then it's a matter of just cutting out the rotted section, cutting and glassing in a new section. If you've never done any glass work before, then get it done by someone who has done it before.
Chris...
you will most likely find that in addition to the engine mounts being rotten and needing replacement, your transom and stringers will also need work.
suggest you pull the drive, then pull the motor. assess what you need to by doing test drills. then start repairing your fiberglass boat by cutting out the rotten and wet wood and replacing it.
since your boat has a 2.5 liter, that puts your boat mid 80's or older
Start by going to the restoration forum. and read the stickies
specifically, links 14, 15, 18, 2, 3, 4a, and 4b of this one. https://forums.iboats.com/threads/how-tos-and-other-great-information.283508/
liusigou
Today I pulled my engine and took the coupler off. it was not difficult to pull it out. But is it easy to get it back and make the engine fixed on the boat?. I has uploaded the four bases to mount the engine. any advice is appropriated
liusigou
First question : How I can make the engine to fix on the boat to prevent being moved?
Second question: What are we going to adjust for the alignment?
Bt Doctur
The rear of the engine is bolted to the rear housing, there is nothing to adjust,pic 3 shows the location of the rear bolts. where the bolts go in are the rear motor mounts. When they go bad the motor lowers and wipes the coupler. So first replace the rear rubber bushings.
pic 1 shows the front mount, the large nuts inthe center raise or lower the front of the motor to get the alignment perfect. Replacing the front mount if its rotted, grad a piece of poplar and glass it in place at the correct height.
the answer to nearly all Mercruiser questions are in the stickies at the tops of the forums.
and if you dont like reading, Achris posted these vids a while back. https://forums.iboats.com/threads/a-couple-of-new-videos.570843/
liusigou
Where can I find the viedo to do the alignment job? thank you
liusigou
Today I bought a piece of oak wood. Can it work if I put the oak wook with right size under the engine? The oak wood is very hard. In the future I will maintain the oak wood and do the alignment by my self.
Did you check for rotten stringers?
If your stringers are rotten, and you are trying to bandaid the issue with a block of wood, is like pulling new pants over soiled underwear after you poop your pants. May look good for a moment
liusigou
I am trying to remove bellow house from sterm and I failed to remove the screw at the last step. How can I remove the screw.
