SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
- Mar 8, 2017
- 1,765
Depending on your access to water, if you can drive to a lake that is the easiest. Just need a couple buddies or couple hundred pounds to just hang out for a couple minutes next to the dock with a grease pencil. Then any leaks found, just circle.
The other option, while not recommended, is to fill the hull up with water and shift it around to get areas covered with water. Then you check from the exterior to see where it is coming from. As a side note, reason why people don't recommend this option is because your hull isn't designed to keep water in, so the pressure is different. That being said, I used this method as we are 1.5 hours from the closest place we can put in to test the hull.
SHSU
SHSU
