JASinIL2006
- Feb 10, 2012
- 5,768
Sorry about your discovery... the Arauco plywood is good stuff. I used it and was really pleased.
I couldn’t find cheaper resin than US Composite, even with shipping charges.
Thanks JASinIL2006 I am ordering today. Did you order your rollers from them also? Those Glasskoter rollers are expensive! ... and thinking a standard short nap nylon roller should work fine, right?
What I would do there (personally, I'd make an exact cardboard template of that layout with an exacto knife, tape and wood glue) after grinding down that stuff I'd graze over the entire hull with a grinder and make an even, level surface of fresh exposed clean laminate.
So, kcon , are you saying you make template stringers out of cardboard first? Or a template that you can set the stringers into (like a photo negative, if that makes sense?)
I'd make cardboard stringers and bulkheads out of cardboard one for one, use a pencil compass to get the exact fit, then use some string and a string level to get the exact height right as well, tape or glue it up, and you have an exact copy of all your parts to use as a trace template to cut. I WISH I did it like that when I started my stringers lol (best way to learn something is to do it the hard way first!), just a suggestion but I believe it will make the process so much easier on you.
