kcon
Thread starter- Joined
- Dec 10, 2016
- 303
As these things usually go, I hit another roadblock. I'm installing my hydraulic trim tabs...
Starboard side, check!
Port side......uhhhhhh.....
So now I have to fill in the bilge pump drain hole lol, of course the trim tab hydraulic actuator would need to be mounted literally right over it!
Question for folks who know paint, have painted using the WOG tractor paint method, and/or question for Woodonglass
I was installing my trim tabs and noticed the area of paint on the transom is very soft, like my pencil tip, with medium pressure, lightly scratched it. It's not that soft everywhere, just parts of the transom. I also noticed when razoring/peeling off the paint around the HIN, that the paint is rather soft and rubbery, almost like a vinyl, whereas I would expect it to chip or flake.
Any ideas on that? Is it possible I laid the paint on thick there and it just needs more time to cure properly. I finished painting the hull 4 days ago. I used the tractor paint method to a T, only I used Rustoleum Farm & Implement for the paint.
If I'm for whatever reason doomed to soft rubbery paint, so be it!
Thanks much!
Thanks much!
