interalian
Thread starter- Joined
- Jul 23, 2009
- 2,105
I'm going to build a motor stand for my 'rude V4. Anybody know the standard transom angle used for outboards?
There is NO standard angle but if you want to emulate yours just use and angle finder and build your stand accordingly. As GAB stated it really doesn't matter...It just a stand.![]()
This is a link to a really nice, sturdy stand
http://forums.iboats.com/forum/boat...749-building-an-o-b-motor-stand-instructional
Got 1 under a heavy weight 60s Evinrude 90 and a late 70s Merc 115. Plus under a couple other motors....
| SERVICE MANUAL LOOP V 87 |
We have really long winters here (often described as "9 months of snow and 3 months of tough sledding") .
so your from Minnesota?
So I built this stand to hold my 85 hp Johnson. I bought a 90 hp with trim tilt for my bayliner Capri, so I needed something that I could wheel around for the old motor. I also use this stand to run the 85hp every so often to keep it fresh. You can see the very small fuel tank mounted to the stand. Ironically this tank is actually the oil tank for the VRO on the 90hp. I never trusted VRO and was the first thing I tore into on the 90 hp. I digress....... My stand is built out of 4" channel and 1-1/2" angle iron, welded together. I used a piece of fiberglass reinforced plywood, (left over from the capri's new interior) to make the transom support. The controls are mounted to the side and fully functional with the cables looped around it. It has really worked out well.
To anwser your question, 12 degrees is not officially standard, but is very, very common on a lot of outboards and transoms
