- Jul 18, 2011
- 19,152
I think we might have a 'winner' . . . Port engine plugs look like they are running quite lean. Starboard engine plugs look more normal. I took some pictures and will post them later.
Also, with my new timing light, I was able to get a better reading on the ignition timing. I did not have my manual with me, so I was not able to set it to base timing mode, but by comparison the port engine looks like it is a few degrees less advanced than the starboard engine.
So at this point I have the following questions:
How best to fix the fuel mixture issue ? Run a high concentration of injector cleaner? new injectors,? take them out for cleaning?
Would the timing being off by a few degrees cause a lean condition?
Would there be damage to the engine from running about 30 hours in a lean condition? My assumption is that it got progressively worse between last season and this season.
Thanks for any thoughts or inputs.
