BWR1953
- Jan 23, 2009
- 6,269
Got as far as I can with the carbs. Need to get parts before reassembling.
Moving on to other stuff...
I can't recall if I showed the throttle control for the 50 Merc from the nasty glasser donor, but it's in bad shape.
How about that hinge? Creative, right?
The good news is that I have an identical unit that I can use. I'm going to CANNIBALIZE it from the Chieftain motor!
What I'm going to do is to move parts around and make one good working unit from two broken units. The Chief throttle control doesn't have a key and the engage/disengage lever/switch at the top of the throttle handle doesn't work. But the KF donor motor control does have those parts, so I'll combine them all and have a working throttle for the KF. Since the Chieftain will have twins, it's going to need a different throttle control anyway. I knew that when I bought it and have been planning on doing this swap/combo thing since I bought the Chief.
