My 1968 Glastron GT160 rebuild......
Corjen1
Sam, there are only a couple kinds of boating folks, ones who have forgot to put the plug in, and those that lie about it!!! :eek:
Here is todays update....
Teak oiled he swim step...
Installed travel chains on the bow seats...
Ran the ToP for about 30 mins on the muffs...adjusted the RPM gauge, had it set wrong. Volt gauge is reading 10.5 volts, but has 12.6 to it... not sure what up with that. At least I know the battery is getting a charge. Also rigged the reverse gear.. not more ticking!!!! While the lower unit lube was hot, drained and re-serviced it.
(Click on image)
Should the fuel filter be completely full while running? motor ran fine at idle-1500 revs. Didnt go over that. Seems to me like it should be full though.
Woodonglass
I have the exact same filter and mine runs and looks exactly like yours. It's never completely full!!!
sphelps
I have been wondering that also .. It was like that on the girls boat and I thought that might be part of the problem when it started acting up .. The guy I talked to at the local boat place said he doesn't like using that kind because they are prone to leak air .. He recommended the one piece disposable type .. But I see the glass type used quite often ..
Tnstratofam
I use the one piece plastic fuel filter and it is never more than 3/4 full. Sometimes as low as 1/2 full while running at higher rpms. Everything is looking FABULOUS! I can't wait to see her in the water and making wake!
Woodonglass
I personally LIKE this style filter and haven't had any Air leakage issues with it. I has replaceable filter cartridges and it does a good job for me. I DO use REAL Gas an NOT Ethanol!!!
Corjen1
Gents, Ill tell you the reason why I like this filter.....when I first hooked up the fuel line (copper, 3/8th od, 1968 original), stroked the bulb, and a bunch of crap came out of the line, trapped in the filter, I was able to disassemble the entire unit, clean and reassemble and reinstall. It has already paid for itself.....something nice about not having to throw it away after one use....
archbuilder
looking good cor! What ever you do don't use ethanol, you;ll only do it once, the ToP will do a meltdown with that crap in it.
Corjen1
This morings update...
this pix is for Sam :eek:
Sits in the water very nice...
Engine runs on the trailer...click on the pix.
I discovered if the bow is high (on the ramp)...the fuel will free flow to the motor...and it was half flooding out. Otherwise all went very well.
tpenfield
Very, very nice. Super job restoring. :thumb: It must feel great to have the boat on the water.
Mark72233
Ensign
She looks very sweet sitting in her natural environment Cor, just beautiful be proud of yourself :whoo::clap2:. What's the story on the shirt :gossip:
kcassells
You surely must of had the heebeegeebees with all that hard work and excitement of her going in!! What a purty really well done boat!
images
ahmincha
That is awesome cor I don't know how you were able to put it in the water and not take it for a ride. Your a good man
sphelps
Beautiful job from the TOP to the bottom !! :thumb::yo:
Btw thanks for the pic ! :rolleyes:
Counting the minutes to seeing some wake ! :pop2:
