1972 Silverline Grand Bahama
boatnut74
Well life has been keeping me busy so I haven't done anything more on the boat. We are in the process of buying a house and are closing on the 9th so I'm trying to button up some of my back burner projects that needed completed.
Had to rebuild the rear axle in my truck as well as change spark plugs which were way past due at 126k.
Now I'm trying to get my new engine done for our ski boat. Went ahead and replaced the wood for the motor mounts as one was soggy.
4.3 bored .030, flat top pistons, roller cam and am upgrading to full roller rockers. Vortec heads with edelbrock intake and holley 4 barrel. It should be sufficient :)
jbcurt00
Welcome back, check in on the SC SOTY, voting starts Mon pm/Tues am...........
boatnut74
Thanks jbc. Seems I have lost touch over the last several months. Life has just gotten in the way of the things I would prefer to do.
boatnut74
A few shots of my latest project nearing completion
[URL=http://s1235.photobucket.com/user/boatnut74/media/FFFD9191-6E06-47F7-80B1-C117877A019E.jpg.html]
[/URL]
Woodonglass
Welcome Back!!! Ahhh Life...Funny how we all experience it in different ways!!! Motor Mounts look Good!!! The Motor should be able to Power you where ever you wanna go. Good Luck on the Closing!!!!:D
jbcurt00
Welcome back w/ a vengence:
Nice top end!
Swing thru the SC forum, it's time to vote ;)
boatnut74
Nice top end!
Thanks! A lot of money in that top end. Should be around 250hp, stock was 190. Hopefully I can notice the difference. I'll be sure to vote.
boatnut74
Almost finished with my new engine swap. Need to track down some elbow gaskets in the morning and some fuel line fittings and hopefully be able to start and dial it in tomorrow.
boatnut74
I got the new motor running today. I am extremely happy. I had the timing within 2 degrees which made for an easy startup. Have a few kinks to work out, leaking thermostat housing and a few of the rockers tick so they will need some adjustment. Overall it went exactly how I hoped. Now to winterized it to protect my investment.
Video upload in progress as well :)
boatnut74
I need to figure out how to post video directly on the thread. Bear with me
dozerII
Nice job on the motor bn74, should make her go real nice. So when is another tin boat going to land in your yard?:rolleyes:
boatnut74
It will probably be awhile on another tin boat. We are in the process of buying a house so that takes priority. I do however have a complete 4.3 gen 2 drivetrain I would love to put in a tin boat.
hadaveha
I've got a crest liner with a 470 oh how I covet that 4.3 you have
boatnut74
Not much to post. Needed a new throttle cable bracket since I switched from a 2 barrel to a 4. I decided to make one since I didn't feel like spending $80 on one.
I also made a roll around stand for my spare 4.3 which is eventually destined for the silverline.
boatnut74
Well, I happened to find out the pistons in my engine are not the correct ones. I got the engine back out and starting tearing it down so I can take it back to get the right ones installed. Just another setback.
