yamaha remote control
robert graham
Re: yamaha remote control
Mine is a 703 also and I can see no way at all for it to be reversible. I've heard of some left hand controls on boats in foreign countries, but believe most boats in the USA are right hand control. You need left hand controls?...
Capt Ken
Remove center bolt and switch to the other side. Very simple
Don S
Don't forget theneutral lock, that has to move to the other side too. Two screws holding it.
speed_demon
The only problem is the t&t will reverse sides too but I guess you can get used to it. Are you running a center console?
Don S
No it doesn't, up is still up, down is still down. The handle changes sides, that's all.
speed_demon
The button is on the other side. I don't know about you but I'm a thumb man. No self respecting american would control his trim with his pinky!
99yam40
I take it he is swapping the handle to move it to the other side of boat and operate with left hand maybe
speed_demon
I've seen left side controls in some vintage boats but most people who need reversed controls are running center consoles. The controls mount on the right side of the outside of the console so the mounting surface is reversed.
Don S
I've run center console boats and have no problems using my index, middle, or ring finger to operate the trim control if the button is on the outside of the control, never even considered using my pinky. You seem to be wanting to create a problem where there normally isn't one.
The OP asked if the handle was reversible, and it is. So what is the problem?
speed_demon
It's really not that big a deal I just wanted to point out that the button will not be at your thumb which is preferred. The last time I ran that setup for dipnetting my wrist got pretty sore. Long periods of unpredictable shallows and boat traffic/waves with constant trim manipulation.
