I'm not sure if this is where I need to put this post, but I wanted to do some winter work on my boat (sort of keep my sanity while waiting for boating season). I live in Chicago and rent a two car garage to store and work on my boat. It gets cold here, and the garage is not insulated. But I'd like to know how some of you winter restorers heat your garages to a comfortable working temperature (upper 40-lower 50 degree temps).
Since I rent my garage, I cannot install any high powered heater. Also, I don't plan to do any "lamination" or fiberglass work where I need an optimal curing temperature. Any suggestions would be helpful; particularly the type of heat source you use.
Some info on limitations: 1. Electricity is limited to 110v. 2. No insulation. 3. Limited ventilation, though the garage is a little drafty.
