erikgreen
- Jan 8, 2007
- 3,105
Re: Winter refit - transom
It's officially effing cold here in MN. Not the worst I've ever seen, but it's past the point where you spend time outside for relaxation unless you're doing some sort of winter sport. I can see St. Anthony falls steaming from my office window as I type this.. the water is just above freezing itself, yet it's steaming because the air is so much colder.
Of course, this is the week that my truck chose to have a brake cylinder seize up, so I get to spend part of the weekend outside in single digit temps trying to take it apart. I think I'll build an igloo and put a torpedo heater in it.
Not much boat work got done last night due to tool failure. Also I was debating what to do with my curved upper transom section. I think I'm going to cut it off and re-skin (after talking to an expert over at bateau.com) to save time and resin. So the transom core when it goes in will stick up 10 inches over the outer hull fiberglass for a while.
I took the newly laminated transom core off the plastic on the floor and cleaned up... the core is solid, dead flat, and ready to go. 15 plies of pine 1.5 inches thick. Tonight I may try setting it in place and drilling clamp holes, etc. I'm not going to try gluing it on until my new shipment of wood flour arrives.. no more cabosil for now.
I think I may try to wire up one of my old cordless saws to work... I need a circular saw and I can't afford a new one ATM. Or rather I can't afford anything decent, and I don't want a junky one.
Erik
Erik
