TOHATSU GURU
- Jul 22, 2004
- 6,164
Re: what oil brands do you use on Yamaha 4 strokes
Kanadakid, I'm not sure what's worse, being from Canada or living in Jersey. NO manufacturer had an oil that would pass the FC-W test....Until they changed their formula. Whether Amsoil changed their formula just before, at the time of or after the FC-W oil standard was developed is of no importance. <br /><br />The point of this discussion is or at least was....Is a non FC-W oil necessary? The answer is still no. Is an FC-W oil better than a non FC-W oil in marine use? The answer is yes, everything else being equal. Does use of a non FC-W oil violate the warranty requirements of any manufacturer who issues a statement that their product requires an FC-W oil. The answer is yes, but it depends on your lawyer.<br /><br />As to your other questions:<br /><br />Fuel dilution and water collecting in the crankcase can occur in any environment. Fresh, salt, hot, cold. It is worse in areas that are colder.<br /><br />As to why I am in the camp I'm in , The facts are the facts. I don't know jack crap about oils...except what I DO know about them. And I know more than you. Regardless of what you or I want to believe there are measurable differences in how an FC-W oil and a non FC-W will perform in marine use. It is very possible that a oil manufactuer may now or will in the future, have an oil that would pass the FC-W level, but not go through the certification process due to the cost. But that's not important, at least not to me <br /><br />If you knew me you would know that I don't cover for any manufacturer of anything. For the record, we almost never sell oil. We do give it away to people when they buy a new engine and we do use it in our service department. But here's the kicker...We charge the same thing for FC-W oil as we did for the older oil, $2.99 per quart. We make less off of the new oil than we did off the older type's. <br /><br />You can believe what you want. I'm not going to change your mind. But I do hope that you will consider the possibility that you might be mistaken about how all this works. Think about it. I was wrong in a post earlier in this theme ..FC-W has nothing to do with cylinder walls drying. See how easy it is to admit a mistake. When your wrong your wrong <br /><br />Also, has anyone else seen the irony that in a forum about oil( a lubricant), there is nothing but friction?
