What do ya'll think?
jonesg
Re: What do ya'll think?
No need to add structure that isn't there, you could end up with hard spots and cause cracking. The woodwork doesn't look bad, is it original? looks like pine board.
I would pull the tank and give it a good cleaning, replumb with new lines, change the fill hose to alcohol resistant.
How's the transom?:)
1955
when all is done use DURABAK paint
The Durabak Company?
Phone: 303-690-7190
Copyright ? 2007 The Durabak Company?
All rights reserved
TXYama
Durabak sounds like some good stuff. I will look into it more when I am closer to being finished.
TXYama
Here is a few pictures of me starting to cut the front platform out. I grinded the paint away to see where i was going to cut. And pictures of where I cut through the hull.:eek:
TXYama
More pictures.
TXYama
More pictures with the platform off. After removing the platform i notice a soft spot on the left front of the hull. Do you guys think I should grind into it and see why?
I haven't been able to do much b/c its been raining and it has gotten pretty cold down here. Well pretty cold for the part of texas im in.
I plan taking out the stringers tomorrow. Any tips? As for the gas tank do ya'll think? Should salvage it? The gas tank has alot of water in it and , a hole with alot of corrosion near the fill hole and breather valve.
TXYama
Been busy with other things. I have not done much since my last posting. But I have a question. What type of resin should I use on the stringers ? And what type of glass? I have been reading a bit about resins and glass but, I want to know what ya'll think?
This boat is mainly used in saltwater for fishing. I usually go with 3-4 people.
lowvlot
I believe most people on here would say Poly resin with 1708 biax would be sufficient.
