vro do i premix
sean64
johnson 60hp 3 cylinedr vro. can someone tell me how it works. And do i remix with 50:1. THANK FOR YOUR TIME
tashasdaddy
Re: vro do i premix
what year and model as there are different pumps.
sean64
Re: vro do i premix
hi bktheking said at a guess 1992+. Donot know model
Vic.S
Re: vro do i premix
No you should not premix if the VRO system is still fully operational
As you have already discovered from your question on Worldseafishing.com VRO means variable rate oiling.
Oil goes in the oil tank and gasoline (petrol) in the gas tank.
The VRO pump mixes them in the right proportions. The proportion varies with the speed, more oil at high speed, less at low speed, hence the "variable" part of the name.
BUT BUT BUT VRO has got itself a bit of a bad name, unjustly perhaps, but nevertheless some owners disconnect the oil system and run on a 50:1 premix.
If the oil pump is still all hooked up try it but be sure it is all working.
It might be safest to put some 50:1 premix in the gas tank to begin with, the extra oil wont hurt, until you know for sure than the oil pump is working.
Boss Hawg
Re: vro do i premix
Just my 2 bits worth (I exspect change) but i'd plug the VRO & pre-mix :rolleyes:
Vic.S
Re: vro do i premix
Before deciding to disconnect a VRO system (or OMS, Oil metering system) it is worth reading THIS ITEM on the engine FAQs board.
With lack of formatting it is difficult to read but it does discuss some of the reasons VROs have unjustly got a bad reputation. It describes the operation of the VRO and offers some advice on overhaul and repair where this is genuinely necessary.
If disconnection is the chosen route then see THIS SHORT ITEM, also on the Engine FAQ board.
kenmyfam
Vic.S
Re: vro do i premix
Plug in your model and off you go.
The point is he does not know the model number! Previously, look back at his earlier posts, http://forums.iboats.com/showthread.php?t=359366 where he produced some general pictures which have lead to the conclusion that is 1992 or later.
nobody pin the livery down more precisely?
sean64
Re: vro do i premix
i will look at the weekend and get back to you all. Thanks for all your help. If the outboard has bin running for a long time with the VRO working and the remix in the fuel tanks Could that have something to do with its loss of power at high rev
