There are a multitude of examples, and I've spent hours reading them, but it appears that it would take even more hours to answer a couple of simple, I hope, questions.
I have a 1981 tinny Starcraft, and have removed the rotted transom. I'm going to be using ACX plywood, as that is the only thing available in this city.
1) I can't find any marine epoxy within 100 miles, and that is at a wholesale warehouse. My new transom board will be about 20x70. How much epoxy would I need? Obviously, this is a first for me, and the stuff seems to be pretty expensive.
2) I saw somewhere, a discussion on the use of SPAR urethane. I can get that locally. Would this be an acceptable alternative?
3) In either of the above cases, should a topcoat of paint be put on? If so, what type of paint?
4) I also saw a thread stating that JB Weld would work for filling holes in the back skin of the transom. It looks as though there has been at least one engine swap, leaving 4, I didn't measure, but guessing 3/8" holes, along with 6 other smaller holes. The thread said to put tape on, and fill the hole. I didn't see where it said what type of tape to use? Leave the tape on, or remove it? Other than welding, is there another more acceptable method of plugging the old holes? I also read that a person should partially drill a larger hole for the JB to fit into, which makes sense.
5) How tight should the new board fit in the hole? Should it be a tight fit, or is having a little wiggle room ok?
That's probably not all I'll have for questions, but should get me to the next sense. Great site!
