Re: Transom rebuild questions
Ok, water, following your advise. I have the two pieces glued, and will attack again tomorrow. I have some blocks on it for weight, and this afternoon, I'll plug the 18 holes in the boat. I'm a little concerned on getting the angle of 12 boltholes that go through the rear and attach to the inside metal. The outside rear would piece that attaches to the motor is rotted too, but I may be able to make a template. I'm guessing that using a very small bit, and running that through to see if I can find the hole in the metal, would be best? Then jump in and out of the boat to see if I hit the hole? The same issue seems to be the only way to do the drain tubes for the back splash. I'm still thinking that the drain tube holes should be done right away, so they can get treated also?
Thanks.
The way I did mine was a bit different, I cut the wood to the correct height and then final shape after gluing the 2 pieces of 3/4" together. I would glue them together, sanding the raw edges is always a good thing to keep from having run away splinters while handling the wood. You can always tweak the aluminum channel just a bit too, it's not going to hurt anything if it's just a tiny bit to allow the transom to slide in better. I know that those channels can create one heck of a mechanical bind on the raw wood.
I wouldn't drill out the holes before gluing and the final fit, it leaves room for a mistake.
Thanks.
