- Oct 25, 2011
- 25,242
Re: Transom problems with Larson 186 SEI I/O Bowrider
Why not just slightly lower the limber hole closer to the hull instead of adding to the hull & trying to raise the hull up to the too high hole?
Just a random thought.........:cool-new:
One of the design problems with this boat was that the drain hole in the rear of the ski locker was about a half inch off the floor of the locker. That caused a fair amount of water to collect in there and caused constant moisture and mold issues. (To make matters worse, it was carpeted -- that stuff was a moldy mess when I removed it) I'm planning to build up the floor of the locker so it will drain naturally via the limber hole to the bilge.
