JASinIL2006
Thread starter- Joined
- Feb 10, 2012
- 5,766
Hi all, I have a '97 Larson 186 SEI I/O bowrider, powered by a Mercruiser 350 Mag engine and an Alpha One Gen 2 outdrive. The drive train was replaced within the last year or two and functions great. We bought the boat last Spring (2012).
Yesterday, while prepping the boat for an outing, I noticed a bolt for the transom-mounted ladder bracket was loose. In investigating how to reseal and tighten it, I did some disassembly in the engine compartment on the starboard side, and I found some badly rotted wood on the transom. (See this thread that has some pics and more info: http://forums.iboats.com/showthread.php?t=570636 ) To recap, after moving some breather tubes and other stuff, I found some really soft, rotten wood in the transom on the starboard side, about six inches from the point where the outdrive goes thru the hull. The fiberglass on the rear of the boat looks great, and there is no movement when I put weight on the outdrive.
I don't yet have any idea about the scope of the problem, because the engine compartment is carpeted on either side of the engine itself, and the interior of the transom is mostly concealed by a carpeted piece of plywood. The wood on the interior of the transom seems OK on the port side, as far as I can tell now. Given how bad the rot is in the spot I tested (I was able to reach in and grab a handful of rotten wood with my fingers), I am assuming I have to replace the transom. I've read a lot of threads here where people have found themselves in similar situations and I think I'm up to doing the work myself. I don't have a lot of experience as a mechanic, but I'm pretty handy and I'm willing to give this a try.
I am feeling a bit overwhelmed, though, and I'm not sure where to start. I have decided our boating season is over, so I am guessing I'll also need to do whatever end of season maintenance/winterizing is necessary to make sure the engine and outdrive are OK. My goal is to have the boat ready for next year -- is that reasonable? I have a two car garage, but I will most likely not have a heated workspace available over the winter (I live in west-central Illinois), so I'll need to get done what I can in the Fall and the Spring.
So what am I facing? Where do I start?
Thanks in advance for your help. I have a feeling I'll be hanging around here for a while...
Jim
Jim
