QC
- Mar 22, 2005
- 22,783
Re: Torque vs. Horsepower, who gets it?
Sorry Bert, I guess it is still analogous, but sorry this is monopolizing your thread right now. Maybe this will help . . .
This is a horsepower, fuel and torque chart from a little 150 bhp Cummins marine engine. It compares a Propeller Load Curve, the power required, vs. what is available. The relatively straight lines on the bottom of each is what the prop requires, the curvy line above is what is available in hp, torque and then the associated fuel. Oh, oh, you can double or triple every number on the chart and be able to consider a 300 or 450 hp example. The differences are not even rounding errors in regards to this discussion.
This illustration is essentially the same for gasoline and diesel except the max available curves at low RPM are not as far apart. Yes, less torque. But here's the whole flippin' point. How are you going to use that additional available power? Upshift? No, can't do that. Go climb a hill? Well I guess there are lots of little ones that we call waves, but there is no place on the water to sustain a "lug" that would allow you to utilize that extra, reserve power. Just a reminder, we are talking boats here. One gear, and no hills.
The bottom lines leave out one thing, the higher load at the point of getting the boat up on plane, and of course that ius different for every hull and why it is excluded. Regardless, I assert in the case of a displacement hull that does not come into play at all, and in the case of a semi-displacement hull (Bert's) it is minimal. So if the propeller only needs X amount to go, and the engine has more power than that is required (say at 2000 RPM) what do we get if we have more torque there? One thing . . . better acceleration. Has Bert mentioned acceleration as his concern? If I missed it sorry, but what I think he wants is more speed and less noise. For me that says turbocharger (natural muffler) or, has Bert has determined, a regular, smaller, lighter, every day, conservatively rated small block with twice as much power as he has now
Great choice.
