Re: Torque vs. Horsepower, who gets it?
You know I had to go back to Classical Dynamics (which I learned in Physics in the 70's......and mostly forgot in the 80's and 90's!!)
(if anyone wants to read about it,
Here's an excellent intro. ) It's a PDF so Acrobat reader, (or whatever PDF reader you're using) will open and display it.
Torque is a force and HP is work
Well, sort-of true.......... Force (F) is applied linearly, TORQUE (F x r) has to be considered with a radius (r) ......so specifically, Torque is rotational equivalent of Force.
But you MUST have the other required component for it to do that work. Speed. (rotational speed......or RPM)
And for example, 400ft-lbs at 2000 RPM is of course,
VASTLY different from 400ft-lbs at 3000 RPM
HP is simply the result of a math calculation.
AND HP is a marketing item. .......... to get people to buy a car, boat, engine, etc. The HP is calculated where it gives the most bang for the buck (from a sales point of view)
If you put a sales brochure together that tells the customer that his engine produces 274 lb-ft of torque at cruising RPM (and it won't be all that different than the other model that does the same thing) it won't be a selling point.
But if you tell them that the super wiz-bang engine makes 400 HP! (even though it's at an RPM the customer will NEVER operate at!!!) YOU HAVE A SALE!!!!!
We've been conditioned to be responsive to that!!! ...........The rest of it is just math. Pretty boring math if you read that great intro to Dynamics above, AND you're an engineer type like me!! :facepalm:....
