Re: Torque vs. Horsepower, who gets it?
And if you have a gear reduction your horse power rating goes down and your torque goes up
And that is false except for the fact that higher gear reductions introduce higher parasitic losses. Here's the math (minus the parasitic losses).
100 lb ft @ 5000 RPM = 95.2 hp
100 lb ft @ 5000 RPM into a 2:1 gear reduction becomes 200 lb ft. @ 2500 RPM = 95.2 hp
100 lb ft @ 5000 RPM into a 3:1 gear reduction becomes 300 lb ft @ 1666.7 RPM = 95.2 hp
Works with overdrive too.
100 lb ft @ 5000 RPM into a 1:1.5 OD becomes 66.7 lb ft. @ 7500 RPM = 95.2 hp
Edit: I have never, not once, said that horsepower is a force. You keep mentioning time without making the connection that force applied within a specific time make power. You can't even calculate speed without time and this is where your words (maybe not your understanding) fall apart.
