FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
floor is deck, depends on the condition, if it is good, and reusable, drill out the rivets, if rotten tear up, and use a grinder to cut off the rivets.
Why are you going to replace the rivits? Do the rivets need to be bucked and tightened?
Consider you might be able to tighten the rivets and not replace them. If you have a partial leak ...... tighten and use gluv-it. Just trying to save you a few bucks.
Thanks, taking rivets out cause we feel they are old and will eventually all need to be replaced, so doing them all at once makes more sense then doing them one by one(?). They are leaking, and the bilge pump is old...
Are there secrets to getting the floor out? Doesn't seem to be screws in places to take out easily? Did the floor clip in, or does it have screws that have to be removed in hidden places? Does that make sense? Does the carpet have to be ripped up???
floor carpet has to come up, the plywood is riveted to the stringers. if they are in decent shape, you will have to drill them out and knock them thru, i used screws to reinstall mine deck.
Well, we took a better look last night and found these... hope you can see them in the picture. They are right where the boat sits on the trailer... can Gluv-It fix that, or should we be looking to weld the aluminum?
