Stringer and Deck Glassing question
othelloears
I am trying to get a definative answer for glassing my stringers and deck. I am rebuilding a 20' 1985 wellcraft elite bowrider with a 305 mercruiser.
Based on reading everything I can get my hands on I plan to:
1) Tape in the stringers with 12" tape and completely wrap with another layer of 1708
2) Tab the deck/hull with a layer of 1708 and coat with 4 oz cloth
I am using epoxy
Is this enough for this boat?
S. Toth
Re: Stringer and Deck Glassing question
yes that sounds pretty good.
Bob_VT
Be certain to bed the stringers in PL...... Use a peanut butter mix smoothed out with a plastic spoon fo the joints where they meet the hull. We have some great epoxy/glass experts here so if you get jammed up just ask.
othelloears
Thanks for the responses. Been grinding all winter and it feels good just to get to the reconstruction point.
I am struggling with the bedding issue. My existing stringers which are 3/4 pine trim board were well off the hull...1/2" to an inch. I have decided against bedding them in peanut butter which based on my research doesn't allow for enough flex/give/movement and can create the same hard spots we are trying to avoid. That being said while I won't use it on the bottom of the stringers I will use it for the angle joint to soften the turn for the 1708. I am assuming PL will give a softer more flexible joint for both the stringers and deck.
How do you upload pitctures on this site?
