Shoestring Starcraft SS160 Resto-mod - let the long slow road begin
ShoestringMariner
Backboards. The originals were plain white vinyl. They looked like arse. So these will be the blue. Nautolex also. I don’t like the way the originals rotted out at the floor. Double wrapping them causes them to retain moisture. I’m not quite sure how I’m going to treat the bottom edge just yet. Before I close up the wrap I might put a finger swipe of 3M 4600 along the exposed plywood to make sure they can’t suck up water.
Watermann
Oh you caught me in my other boat!!
Is this photo thing looking permanent? I’m getting older but still working 44 a week, and also trying to wrap up many projects. If I don’t have to go to another site and learn that one that would be better however, if this is a permanent deal, I guess I’ll have to.
MS Onedrive comes installed on all windows computers and I use it on my phone to upload pics, it will be around as long as MS is I guess. I went with Onedrive figuring it was the best and not going away. I made a tutorial for it some years back when the forum pics were messed up and photobucket kicked the bucket.
Watermann
You can do the same with dropbox pics, just have to copy the link and then add it using the photo link button above.
Watermann
That is unless the pic gets moved or deleted from it's original location.
Rasdiir
Todays progress; Still very slow but moving forward.
I wired up the rod locker lights, tested it and installed it and tan the leads. Swivel bases were installed on top of some .080” or .100” thick neoprene gaskets That I made. (Which I hope doesn’t react with the vinyl) I have to figure out a quick removal attachment for the sleeper seats so it looks good when the swivel seats are used.
I marked existing rivet hole locations on rib ends using a good idea from @renns and target locations for new ones. I had to do some styro shaving as there was a few high spots but I think the boards are ready for fastening once I lay out the rivet pattern.
I mocked up a few items. Wondering about making the side board longer to hide the gap at the floor to hull. Maybe terminating the side board into the console front wall. I’m also thinking about adding a board above it under the console so I can mount fuse blocks and bus bars. Thoughts on this? Anyone else do this?
Also considering re-cladding and reusing the sliding doors at the splashwell. I don’t particularly like this set up or design, but it looks like a mess left wide open, so until I re-work the splashwell, it will have to do. The track was petty rough. I straightened it out. Some work with some files and nylon wire wheels will clean it up enough so it’s not offensive. Again, it’s probably temporary.
Tomorrow I’ll have the floor riveted and then I can wrap the last piece. I’m going to mock up the consoles and figure out the V-bench new configuration. The footwell is going to be smaller to create more storage beneath. I’m concerned with the footwell size being to tight. Anyone reconfigure this for the same reason and find it either worked well or was too cramped?
I see in the pics here: https://forums.iboats.com/threads/s...-the-long-slow-road-begin.721077/post-5752612 that you did the same thing I'm planning on, having a pedestal and removable B2B seat on the passenger side. I was measuring out my seat placement today and it doesn't look like I can unfold a B2B because they only unfold from one end and that would mean the base basically has to butt up against the splashwell at the rear. The original B2B in mine unfolded from both ends so the base could still be centered between the console and the splashwell. Did you have to do any adjustments to your seat location to accommodate it unfolding?
Also, I think I asked you this sometime in the past, but what are you using to mount the B2B? I was just going to use t-nuts and bolts the same as the pedestal mounts, and then put the bolt back in to cover the hole when the seat is removed.
ShoestringMariner
Finally got some time to pick away at this project again. Still struggling from ongoing health setbacks, but trucking through it. The positive of it is that it has afforded me time to play in the shop, a luxury I haven had for some time.
I finished building and cladding the helm fronts and dash faces with nautolex. I think I’m going with the stainless wheel because its shiny and I can see through it better. The other is 90’s dated, dark and chunky (though has a great feel to it) Any thoughts welcome regarding your experience and dislikes of either/both type. I’ve not used these before.
I went a little switch heavy. I was going to use only the 6 switch panel, but then found the auto bilge switches which I preferred more. I may move these to the side panel next to the driver seat and use that spot for a tach. Still time to make that decision. I will have 2 toggles left for something else down the road which is better than none.
Next up; making new side panels, cladding the aluminum V-tub/upstand and making/cladding the rod locker door. Then in to the V bench boards and lift out casting floor-filler panel. (Will convert V-bow bench seat to full casting floor)
Stay tuned, the Tortoise journey continues….
BWR1953
The stainless wheel is definitely easier to maintain. Down here in Florida, they can get pretty hot, but up where you are there should be no problem.
Gotta love a Brodie knob. I have one on my tractor. (y)😁
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
+1 for stainless too
I do 95% of my steering via the brodie knob.
SHSU
ShoestringMariner
Thanks guys, going with the stainless wheel.
Anyone do something different with the side panels? I’m about to start mine. I don’t like the unfinished area under the helm. I understand why they stop short, and are mitred on a slight angle (to avoid at curve of the bow).
I’d like to close this in but making a filler piece that meets the original board on a compound angle, and a tight butt up to the helm front panel may be tricky for me to get cleanly.
Wondering if anyone has done something nice looking here. I may want to add a foot board later too.
Lastly, this board tapers in height from 13” to 11” towards the stern, assumingly for easier storage access. Anyone change this for deeper storage? If so, how do you like the results?
ShoestringMariner
Ok so the stainless wheel gets the final nod!
Spent some time working on the front bow bench. I didn’t like the too-small sized aluminum upstand support I made, so while I’m waiting to make another, I cobbled one up in scrap plywood in order to do a mock up. The top panels have been made to suit a better sized opening (but smaller than the factory original) and now off to figure out the hatch openings.
There will be a trolling motor battery under each seat, tight to the bulkhead. Future lithium batteries will be going in. Should still be lots of room for storage up there.
SHSU
I wish I had thought of future expansion for Trolling motor batteries a little better. Planning for access now is the best thing.
Any reason for the bilge pump up at the front?
SHSU
ShoestringMariner
SHSU
Thanks, I hope it wasn’t a dumb idea. I have one front and back. This boat sits more level with the front troller, 2 batts and an anchor up front. Because the hull can hold a lot of water in the front with heavy rains or a swamping, I wanted to pump water from wherever it collects in unpredicted event if the engine failed. There’s a lot of foam under the floor, so I’m not sure how well the rear pump would work alone in a severe swamping
SHSU
Two is better than one. Mine is a little back heavy. But that might change as I start shifting batteries around with addition of trolling motor.
SHSU
ShoestringMariner
Hey guys, starting to plan the hatch lids for the front section and rod locker. Budget is tight, I’m using nautolex clad plywood opposed to formed aluminum for the lids. The opening in the bench will have an aluminum perimeter frame that is screwed down. (See pic). These hatches will not be water tight.
Wondering how I should treat the perimeter of the lids. I’m going to wrap around the sides and return an inch underneath. Having the corners of the lid itself wrapped tight is going to be tough and this is going to be a water intrusion point. I can wrap the corner with a small bit of vinyl and then the full sheet over it, so the seam crack at the corner has vinyl behind it.
Aside from water intrusion, I don’t think the corners will stand up well to wear and tear. Should I frame out the hatch edges with formed aluminum angle too, at least on all sides but the piano hinge?
SHSU
If you wrap with vinyl, does it still sit flush or will it be slightly higher because of the extra fold underneath? Painting the hatch regardless, to prevent water intrussion would be a minimum. That being said, if you aren't to worried about astestics, you can treat it as a consumable and every couple years just replace with a new painted plywood hatch and not wrap in vinyl.
SHSU
ShoestringMariner
SHSU
Thanks, yes, I am doing the OTF preservative (old timers formula) and spar varnish on the underside. Full bedding of nautolex glue on top.
I also smear 5200 along the cut end of the ply, especially if there are any voids exposed.
After such a long, multi-mothballed project, I really want this to be a one and done, never repeated project. That being said, I might be over thinking its use. I’m late 50’s, not yet retired and this is a dry-stored day boat. How many times will I use this boat before I’m too old, or that piano falling from the sky gets me?
100days? 500? I can’t say for sure, but I may not wear this thing out as hard as I try….
As for flush, will be close to flush with aluminum frame, allowing for wrap. I’m using 3/4” ply (actual dim) for rod locker door. I could do same for hatches, though I can utilize the cutouts if I trim them up. I used a thinner 5/8”’ply for the bow seating (9/16” actual dim) so a shim bar underneath may be required if they finish out to shallow.
And I know I’m being picky. All of this to be covered by cushions again most of the time.
SHSU
Only thing to think about is where water might pool and sit in contact with the lid. As long as there is some space for the underside to breath where it contacts the alunimum frame so water doesn't get traped for a long time you should be fine.
SHSU
