BoatingCop
Thread starter- Joined
- Aug 28, 2007
- 408
Well as some of you may have seen, I was looking for an older outboard engine just to play around with for my first rebuild. Today I had a guy call me and told me he had a '73 Johnson 40hp that he would give me for $50, so I said I'll be there! He says that he went through the carbs and cleaned the points to where it would get spark. He said shortly after if stopped getting spark possibly due to condensers. For $50 I didn't even cared if it was close to running!
Everything but the tiller handle looks to be there. (Serial# J3799944 Model# 40R-73D) This model has electric and pull start. All the wires are there but none seem to be marked. It looks to have a lot of oil that has leaked from the lower unit which I'm going to have to look into. I am going to get an OMC manual if there is still one to be had. I can't remember the web site to order the manual though.
I'm going to go ahead and re build the carbs again and take a look at the points once I get my manual in. I'm also putting in a new water pump. I can't wait to get started!! Does anyone know where I can get a tiller handle? Also will the standard Johnson fuel connecter connect to this fuel hook up? I'm also going to test compression tomorrow. Any tips on this engine are greatly appreciated! I'm also including pics. One of the pics show to be what I think is the water pick up. Can anyone confirm? I've only worked on the late 70's Johnsons. Also, I don't have anything to hang the motor from yet. Is there anything that someone has made pretty easily or maybe just a saw horse? Also pic #5, is this factory? Itt just looks to be hanging in the elements. Thanks
5
5
